Old 10-27-2016, 11:29 AM   #1
AZ986S's Avatar
Why not tap into the harness wires with wiretaps?
Also, you mentioned this was only for cooling down engine bay AFTER the track session. Makes sense, but would there be a benefit in running it DURING the session to help cool airflow around the oil cooler and help keep oil temps down? How many CFMs is the fan?
2002 Boxster S - NHP 200 Cell Headers,test pipes,Borla CatBack,Competition Plenum,74 mm TB, EVOMS Tune,Tarett UDP,Eibach Swaybars,BIlstein PSS9s,TuneRS rear toe links,wheel studs,15 mm wheel spacers on all 4,EBC yellow stuff pads,Sebro rotors, EBS oil baffles,160 deg Thermostat,2 quart Accusump,full filtration remote oil filter,rad fan switch,custom gauge/switch plate, Race Capture data logging, 90K miles
AZ986S is offline   Reply With Quote
Old 10-27-2016, 11:58 AM   #2
The oil cooler is cooled by engine coolant, not air flow. If you want to lower oil temps, use a larger cooler on a base car, or lower the coolant temperatures.
Old 11-03-2016, 05:40 PM   #3
My solution simply adds a manual switch to command "On" the relay.
Using wiretaps and a switch to go direct to the fan would bypass the relay which is not a very good approach. Relays exist for a reason.
How To Use Relays and Why You Need Them
Old 11-09-2017, 08:09 PM   #4
Why not put in an adjustable thermostatically driven relay?
Any time you get 60C or more the fan goes on until it comes down to 60C.
2003Boxster
1973 Carreras RS tribute
2000 Saab Aero wagon stick
1990 Chevrolet pu pre runner
boxfix is offline   Reply With Quote
Old 01-31-2021, 10:47 AM   #5
notech's Avatar
Hi, while attempting to get the compartment fan manually working I might have shorted some of the pins of the relay on the picture.
The car runs like poo, seems like half bank or half of the cylinders, spoiler went up and doesn't go manually down.
Car shows Christmas lights of errors on the dash, for example PSM.
I have checked the fuse box under the dash, I couldn't any burned fuses.
Anything more to check?
What could have gone wrong? Any diagrams I can get?
I am puzzled how any of the relay pins could have messed up with electronics and hopefully not a damaged ECU.
notech is offline   Reply With Quote
Old 01-31-2021, 02:00 PM   #6
notech's Avatar
So I'm still thinking and investigating what could have gone wrong.
on the list to do:
check for error codes and reset
check 40a fuse on relays
check maf / try run engine with maf disconnected
check coils
possible variocam solenoid
that would only partially cover engine missfires but what about PSM, ABS, spoiler lights?
