Old 10-27-2016, 11:58 AM   #2
JFP in PA
Originally Posted by AZ986S View Post
Why not tap into the harness wires with wiretaps?
Also, you mentioned this was only for cooling down engine bay AFTER the track session. Makes sense, but would there be a benefit in running it DURING the session to help cool airflow around the oil cooler and help keep oil temps down? How many CFMs is the fan?
The oil cooler is cooled by engine coolant, not air flow. If you want to lower oil temps, use a larger cooler on a base car, or lower the coolant temperatures.
