Old 09-07-2015, 08:17 AM   #1
Originally Posted by thom4782 View Post
Yes, I think its best done from inside.
IIRC if you peal back the carpet from the front and center of the passenger foot well, you can see where the tube runs from the AC/heater box through the floorboard. I believe you can simply pull it out on both ends and clean it.
There may be residual water in the box the comes out when you pull out the tube so put some absorbent material down before you disconnect it from the box.
It is best done from underneath by blowing low pressure air through it, never using a wire or any other solid object to push through it. Also, do not pull on it, if it becomes dislodged from the heater box, it can be difficult to reconnect.
Old 09-07-2015, 12:57 PM   #2
Porsche9's Avatar
Thanks JFP. I went under the car and can't find the drip line for the AC. I found what I believe is the fuel overflow drip line in the first photo but not the AC drip line. Do you have to remove the under body pan to find it?
03 Carrera
89 Carrera 4
89 944 S2
78 911SC
Old 09-07-2015, 03:05 PM   #3
It should come through, but may have been inadvertently blocked behind one of the belly panels when it was removed previously.
Old 09-07-2015, 04:13 PM   #4
Porsche9's Avatar
I guess it's mean getting on my back and removing the belly pan. Thanks.
03 Carrera
89 Carrera 4
89 944 S2
78 911SC
