Old 09-07-2015, 08:17 AM   #1
JFP in PA
Originally Posted by thom4782 View Post
Yes, I think its best done from inside.
IIRC if you peal back the carpet from the front and center of the passenger foot well, you can see where the tube runs from the AC/heater box through the floorboard. I believe you can simply pull it out on both ends and clean it.
There may be residual water in the box the comes out when you pull out the tube so put some absorbent material down before you disconnect it from the box.
It is best done from underneath by blowing low pressure air through it, never using a wire or any other solid object to push through it. Also, do not pull on it, if it becomes dislodged from the heater box, it can be difficult to reconnect.
