Old 03-29-2016, 04:39 PM   #261
Originally Posted by Van914 View Post
Should feel like a rifle bolt. Mine does.
I'll second that. Very positive feel to it. Gonna take some getting used to it.
And since winter just came back, might be a few days....
onaFLYer is offline   Reply With Quote
Old 03-29-2016, 08:24 PM   #262
Dubaday's Avatar
I couldn't resist, installed it today. Very impressed, thanks again.
2000 Boxster S, SPEC stage 1 clutch, Fabspeed sport headers, Fabspeed secondary cat deletes, Billy&Boat muffler, EVOM air intake, Ben006's Custom Short Shifter, Pedro's TechnoBrace, Eibach rear sway bar, De-snorkeled, Fred's custom projector HL
Dubaday is offline   Reply With Quote
Old 03-30-2016, 05:58 AM   #263
I would really like to buy one! Please let me know of you still have one left.
Edreamsz is offline   Reply With Quote
Old 03-30-2016, 07:02 AM   #264
Ben-Auto-Design
Ben006's Avatar
I'm starting a new round, I'll PM you right now
Porsche Tech in France.
www.benautodesign.fr
1982 928 S Euro
Ben006 is offline   Reply With Quote
Old 03-31-2016, 02:17 PM   #265
Yellow986S
Yellow986S's Avatar
I'm interested in one for the new round. Please pm me with pricing.
Yellow986S is offline   Reply With Quote
Old 03-31-2016, 05:40 PM   #266
Ben-Auto-Design
Ben006's Avatar
Done
I installed a shifter today!
Took me around an hour
few tips:
-To remove the center console, it's better it the hand brake is a bit loose: it has to go high. You can also engage the 4th gear, you'll have more room to remove it.
-Get that: SureBilt/4 pcs. seal and O-Ring remover set 82030 - Read Reviews on SureBilt #82030
It can be used to remove the lower section of the mid console, pry the shift boot and access the screw hidden under the coin holder!
Trust me, it will save you a LOT of time!
-Use zip ties to mark the position of the cables in their holders, and use bigger zip ties to hold the spring compressed when you put the cable back in:
We have almost reach the minimum amount of people to start
Ben.
1982 928 S Euro
Old 04-02-2016, 08:05 AM   #267
I have had my 99 3.4 for almost 2 years now but just now finding some time to work on, get back to the forum and discovered both of the Ben threads. Ben your enthusiasm is impressive!
PM me and let me know what info you need, I want a shifter from the next round. I haven't turned a wrench much in the last thirty years but did enjoy replacing the rotors, pads and sensors last week.
Still trying to education myself about induction options and what will work best for my 3.4. Currently the throttle response is not very smooth and I am sure there is a way to get more out of it without spending a fortune.
99 Box 3.4, PSS9's
cbadbox is offline   Reply With Quote
Old 04-02-2016, 09:33 AM   #268
Ben-Auto-Design
Ben006's Avatar
Pm sent
1982 928 S Euro
Old 04-02-2016, 09:41 AM   #269
Thanks for the advice, I'll be educating myself as I now have the time to play with the boxster.
Sent my info
99 Box 3.4, PSS9's
Old 04-04-2016, 10:09 AM   #270
I'd like to get in on a new shifter too please. I'll send you a PM
Thanks,
Jeff
1999 Boxster Base Ocean Blue Metallic 85k mi. New to me on 04/2014 w/ 83k mi.
Jschindler is offline   Reply With Quote
Old 04-04-2016, 01:24 PM   #271
Ben-Auto-Design
Ben006's Avatar
Done, three more available !
1982 928 S Euro
Old 04-06-2016, 12:10 PM   #272
I replied to your PM .
Old 04-07-2016, 04:36 AM   #273
Sent you an email, Ben.
Old 04-07-2016, 10:08 AM   #274
Ben-Auto-Design
Ben006's Avatar
One more to grab!!!
I've just ordered the base shifters!
Ben.
1982 928 S Euro
Old 04-07-2016, 04:42 PM   #275
Ben-Auto-Design
Ben006's Avatar
Hop, no more to grab!
Sold out for this time
Thanks guys!
Ben.
1982 928 S Euro
Old 04-09-2016, 03:22 PM   #276
Ben-Auto-Design
Ben006's Avatar
Hi guys,
here is the link to follow the bearings shipment. Since it's usually to longest to arrive, you can consider that once I receive them you'll receive your shifter soon after
https://tools.usps.com/go/TrackConfirmAction?qtc_tLabels1=LK110064564HK
Ben.
1982 928 S Euro
Old 04-15-2016, 09:33 AM   #277
Ben-Auto-Design
Ben006's Avatar
Here's a good mod if you have a BBSSK
I'm going to shorten the knob even more...
1982 928 S Euro
Old 04-17-2016, 10:04 AM   #278
1998 Boxster Owner
Installed short shifter this morning - the only rookie mistake I made was not ordering a new Shift linkage Coupling, mine was fairly warn. I just ordered a new one from Parts Geek. Hardest part was removing the original shifter. I used a dremel to shave down the plastic then a large flat head screw driver to push it out. Will take it for a spin this evening - wife had to leave and I have the little ones with me.
Thanks again Ben006
Benitom is offline   Reply With Quote
Old 04-17-2016, 12:13 PM   #279
amagalla's Avatar
Please let me know when you make another run of these.
Thanks.
Tony
Lapis Blue 03 Boxster S
Old 04-17-2016, 05:48 PM   #280
Ben-Auto-Design
Ben006's Avatar
I will
Benitom: Cool, tell me how you like it (I hope you do!)
Looks like the shifters will be there tomorrow, and the bearings too, so everything should be done before next Monday!!
Thanks guys!
Ben.
1982 928 S Euro
