Old 03-31-2016, 06:40 PM   #266
Ben006
Ben-Auto-Design
Ben006's Avatar
Done
I installed a shifter today!
Took me around an hour
few tips:
-To remove the center console, it's better it the hand brake is a bit loose: it has to go high. You can also engage the 4th gear, you'll have more room to remove it.
-Get that: SureBilt/4 pcs. seal and O-Ring remover set 82030 - Read Reviews on SureBilt #82030
It can be used to remove the lower section of the mid console, pry the shift boot and access the screw hidden under the coin holder!
Trust me, it will save you a LOT of time!
-Use zip ties to mark the position of the cables in their holders, and use bigger zip ties to hold the spring compressed when you put the cable back in:
We have almost reach the minimum amount of people to start
Ben.
ASE certified Automotive Master Technician.
Porsche Tech in France.
www.benautodesign.fr
Ben-Auto-Design : Performance parts for 9X6 / 9X7
1982 928 S Euro
Ben006 is offline   Reply With Quote
