06-08-2014, 12:49 PM
#41
Got the Arduino Nanos on Friday. I ordered the nanos that don't have the on-board USB to serial to save space and complexity. The only problem is I can't for the life of me find my "ftdi friend" usb to TTL converter to program them. I just ordered a replacement, I'll update when it gets here and I can program the nano. It'll undoubtedly be at least a week for it to get here.
06-08-2014, 12:56 PM
#42
Could you give us a pinout (EBC) on the transistors...the voltage regulator is pretty self explanatory.
06-08-2014, 02:47 PM
#43
the transistor is acting like a switch and switching ground. It doesn't matter which way they are connected as long as the base is connected via the resistor to pin 2 or 3 as applicable. The middle pin is the base.
Polaris,
Can you email the actual Arduino sketch file? I would like to try what you got working before.
06-11-2014, 12:10 PM
#44
JayG I took a look at the code and it seems fine and compiles, however I am using the Arduino v1.1 software on a Win7 PC.
With this and other projects I have worked on it seems that the newer versions of the Arduino software has more bugs.
Try Arduino version 1.1.x
Also, the transistor orientation is important since a transistor can act as a diode and only allow current to flow in 1 direction.
If the transistors are backwards you may only be able to raise , lower or do neither.
Does anyone see any benefit to making the Arduino boards any smaller?
If so I may try to implement this on a TI EZ430-F2012 which is smaller literally than your thumbnail.
06-11-2014, 01:17 PM
#45
I can compile and load perfectly, its just it does not seem to work properly
Good catch on the transistor. Like I said, it been a very long time since I played around with electronic components
I don't see where I can download 1.1, but I have tried 1.5.6 and 1.0.5
Hopefully Polaris will be able to shed some light on this when he is able to try a NANO
06-11-2014, 07:56 PM
#46
06-11-2014, 08:22 PM
#47
That's what I have been using. I tried 1.5.6 today as well
The problem I have is not compiling or loading the code, its that it doesn't work properly
The top motor only runs as long as I have the switch pushed, just like stock. A momentary push does not keep the top moving
06-12-2014, 10:48 AM
#48
Can you post a nice high res, close up picture of your arduino?
The code works, I've been using my setup for over a year and 2-8 times a day (when the weather is good) without a single issue.
06-20-2014, 09:18 AM
#49
JayG, any update on getting a picture of your setup?
I'm still waiting on the usb to serial programmer to get here.
06-20-2014, 09:34 PM
#50
I'm traveling currently and will be back on Monday. I'll take some pics then
06-21-2014, 07:32 PM
#51
Polaris please send me a note if you can make me an auto-top . I would like to buy one from you. Thanks, Lee NY
06-26-2014, 09:11 AM
#52
OK, finally got a chance to take a few pics
Polaris,
A few questions
Have you been able to get a NANO to work ?
Do you have any special libraries loaded?
the reason I ask, is that you define some variables and I dont see them referenced anywhere in your posted code
#define openTime 15600;
#define closeTime 16400;
I have double and triple checked my wiring. I did make 1 modification, the pins used for the outputs so I could use the header cable I had. I changed the pins in the code as well
The header cables also make a great transistor socket
06-26-2014, 03:52 PM
#53
The MovementCount veritable should definitely be getting set to either openTime or closeTime depending on the button pressing. Maybe I posted the wrong version of the code....like a bone head. I'll have a look through my files when I get home from work.
06-26-2014, 06:45 PM
#54
I have brain farts all the time
06-27-2014, 07:26 AM
#55
well craptastic. Looks like the final version got overwritten with the second to last version. I'll go over the code and figure it out and let you know.
On a side note, they are sending me "another" ftdi friend as it's now been 20 days since I ordered the previous one. Looks like USPS ate it.
06-27-2014, 07:28 AM
#56
Thanks, I appreciate it
06-27-2014, 07:47 AM
#57
I'm pretty sure the last switch statement should just look like:
default: //no movement currently
if(openBtnCount > 0) {
openMode = 1;
movementCount = openTime;
digitalWrite(closeBtnOut, LOW);
digitalWrite(openBtnOut, HIGH);
} else if(closeBtnCount > 0) {
openMode = 2;
movementCount = closeTime;
digitalWrite(closeBtnOut, HIGH);
digitalWrite(openBtnOut, LOW);
} else {
allStop();
I'm also pretty sure the "movementCount -= loopInterval;" lines shouldn't be in the case 3 and case 4 and default switches. They are unnecessary in case 3 and 4, and constantly decremented when there is no motion in the default case.
06-27-2014, 08:12 AM
#58
openMode = 1;
openMode = 2;
} else {
allStop();
just tried those changes and the output still does not stay high except for the time when the switch is closed, in other words no auto operation.
I am using the onboard LED (pin 13) as the output for testing as it is easier than uploading the code and installing in the car to test
06-27-2014, 09:08 AM
#59
do you still have your delay(50) removed?
06-27-2014, 09:09 AM
#60
...and delay(50) should be delay(loopInterval)
