Old 03-30-2015, 08:03 PM   #21
Unhappy
I need help. I tried to install this today and failed. Getting the old shift knob and boot was hard, but I got it done without any damage. I can't say the same for the new pieces. I've managed to crack the knob and tear the boot.
The knob wouldn't snug down over the shaft. So I tried to tap it down with a hammer and padding but still put a big crack on the top. Re-reading the comments above, maybe a metal file would have helped.
After I got the knob settled, or so I thought, I couldn't get the boot to pull up and attach to the knob. I managed to make two rips in the boot while trying.
I've contacted the seller hoping to get replacement parts without having to pay full price, we'll see if they take pity on me.
So, can anyone give me step-by-step instructions? Any other tips if I'm able to try again with new parts?
Randy
2002 Boxster Seal Gray Metallic: Desnorkled, Changed ashtray to non-smoker's bin, Removed stickers from sunvisors, Added rear speakers, LED Shifter, Porsche logo on trunk lid, New top with heated glass window, Aspheric Driver's Side Mirror Upgrade, More to come...
randy7601 is offline   Reply With Quote
Old 03-31-2015, 08:22 AM   #22
98 Arctic silver 986
tommy583's Avatar
Originally Posted by randy7601 View Post
I need help. I tried to install this today and failed. Getting the old shift knob and boot was hard, but I got in done without any damage. I can't say the same for the new pieces. I've managed to crack the knob and tear the boot.
If I remember correctly, I attached the boot to the knob first. So file knob opening to fit first, but don't screw down. Take knob back off shaft. Then attach boot to knob, being careful to face the boot the correct way. Place knob and boot on shaft, tighten knob to shaft. Then pull boot down and snap into place. I hope this helps and good luck with replacement
Old 03-31-2015, 08:43 AM   #23
drew44's Avatar
Randy...I had exactly the same situation as you did. I tried and tired to get the whole thing to fit and wound up cracking the top piece as well. I messaged the company and they sent me a replacement piece, however they did charge me a small fee for it but worth it as it was my mistake for cracking it. I took a file to the inside of it. It really took some time and patience to get the inside filed down enough to make it fit. It seemed like there was quite a bit that needed to be filed down. Once I got it opened up it ft perfectly and looks great! Hope they can get you taken care of, they seemed to be pretty easy to work with. Let us know how it goes!
drew44 is offline   Reply With Quote
Old 03-31-2015, 10:49 AM   #24
Wallace River's Avatar
Makes me wonder if enough people are asking for replacements because they have to file it or force it fit, they might make some adjustments to their manufacturing.
The name's Ian....now a former owner.....sold my 2000 Speed Yellow Base to its new owner in Nova Scotia.
Wallace River is offline   Reply With Quote
Old 03-31-2015, 11:10 AM   #25
Seller has asked for pictures of the damage. I'll send that to them.
Randy
Old 04-02-2015, 01:55 PM   #26
Seller is sending replacement parts for a small fee. Perfectly reasonable considering how I screwed things up. Now I wait.
Randy
Old 04-02-2015, 02:20 PM   #27
drew44's Avatar
Glad to hear it worked out for you as well....here is what I did to mine when trying to hard to get it to fit...
When they saw the picture i sent them they noticed that the ring around the insert was damaged too so they offered to send a replacement for that . They were very easy to work with and I thought since it was my fault they did not try and charge me a huge amount or try to get me to buy a whole new unit.
Old 04-09-2015, 08:20 AM   #28
Here's what I did to the shift knob:
And the boot:
Now I just wait on the replacement parts.
Randy
Old 04-09-2015, 10:08 AM   #29
heliguy's Avatar
I've got that one also in Amber. I love the quality.
Old 04-16-2015, 08:46 PM   #30
Replacement parts arrived today. I replaced the broken shifting pattern insert, and I tested the LED on a 9v battery. It glowed nicely, I'm sure it will handle 12v when it's wired in.
I bought two metal files: flat and round, and cleaned up the inside until it slipped on the lever nice and neat. Yes, it took a while but I'm satisfied with the fitting.
They sent a complete boot assembly too. I didn't break or tear anything, but that's still where I'm getting hung up. After trying for two hours, I just cleaned up and put the original shift knob back on. I can finally see how its "supposed" to fit, but I just can't spend any more time with the fitment.
I'll try again on Monday, my next day off.
Randy
Old 04-25-2015, 02:07 PM   #31
Need help again
Ok. The gear shift and boot are installed - no rips or cracks. Looks really nice. But...
Darn thing doesn't light up. I spliced to power and ground wire to the ashtray light. Should work - right? Ignition on, car running, nothing. Headlights on, car running, nothing. I don't have a voltage tester (I'm going to get one), but this should be working - right?
The wires to the gearshift are red and brown. The wires to the ashtray light are blue and brown. I spliced brown to brown, and red to blue. I even tried reversing polarity, no luck.
I don't know if the ashtray light ever worked, it was disconnected when I got the car. So maybe there's no power.
What else can I check?
Randy
Old 04-27-2015, 06:23 PM   #32
Unhappy
I checked the voltage where I connected the shift knob. I have 12v with the car running and the headlights on. But still no light from the shift knob. I've emailed the seller, we'll see what happens next.
Randy
Old 04-27-2015, 06:59 PM   #33
tommy583's Avatar
Make sure you didn't pinch one of the wires. I'll check if I can see how I connected the wires before I bring the car into the shop tomorrow.
Old 04-28-2015, 04:15 PM   #34
IT WORKS! Apparently, it has been working. Up until now it's been pretty sunny outside, so I didn't notice the light coming on. (It's not real bright.) I didn't even look at night.
Today was overcast and OMG I can see the light! No, it's not real bright, but perfect for night-time use.
The shift knob is wired to the ashtray light. It only comes on when the car is running and with the headlights on.
Thanks to everyone who posted their help. It is nice having a support group !
Randy
Old 04-28-2015, 04:28 PM   #35
tommy583's Avatar
Sun? What's that? We don't get sun up here for another month lol. I'm glad everything worked out for you.
Old 04-28-2015, 04:59 PM   #36
Very glad you got it figured out and working. I was waiting to see how you made out before ordering one
Old 04-28-2015, 08:27 PM   #37
Lessons learned:
Fasten the boot to the knob, there is no need to ever take the two apart.
Make sure the 3 set screws are completely backed out of the shaft opening.
If the shift knob doesn't slide on easily, file the opening until it does. This may be easier with the boot off, but why risk it.
Once the knob slides on easily, tighten the 3 set screws and be done with them.
Now, connect to your electric source. I used the ashtray light. The leads on the ashtray light (on my 2002) are blue and brown. The leads from the shift knob are red and brown. Connect red to blue and brown to brown. Test with a voltmeter, 12v appears with the car "running" and the headlights on. I used wire nuts to complete the connection.
Now you can snap the boot in place. Reattach the ashtray/bin assembly (if used). You're done.
If I hadn't screwed up the installation the first time, this is an hour of labor. If you break something the seller will replace the parts for a small price. They're a German company, shipping takes some time.
I think I'm the first person to tear the boot. They said "how did this happen? we see that for the first time."
But most important: I am super pleased with the result! It looks awesome, and the yellow is the same as the amber dash lights. I'll upload a picture as soon a I can.
Randy
Old 05-06-2015, 01:33 PM   #38
Here it is:
The mark between 1 and 3 is just a reflection.
Randy
Old 08-04-2017, 03:26 PM   #39
So I recently bought my Boxster and the original shift knob was in the center console. It has an LED one on the shifter, which looks much cheaper than the one you have, and I'd like to put the original back on. Do these things just pop on and off?
McHeinzky is offline   Reply With Quote
Old 08-06-2017, 06:52 PM   #40
redciv1's Avatar
Picks of the led unit on now as I might b interested?
redciv1 is offline   Reply With Quote
