Old 01-14-2017, 06:47 AM   #11
Try to rule out the small LED ballast that connect to the parking light by swapping it with the one/side that works. Would be nice if it would only be that. Few failed but we just never know. If indeed the angel eye themselves, I am happy to send you out a replacement bezel assembly if you intent to replace the faulty side one day.
RE inspection. Crazy stuff, sorry to hear your pain there. Idea; can you satisfy your officer by installing a high power 12Vdc LED bulb (temporarily)? I see a 15~30min easy job if you can get the bulb locally.
Mine are also painted black and I am getting plenty of reflection coming out of the stock parking light bulb. I don't have angel eyes in mine so I just kept the oem bulb in there.
Any colors; as long as the surface is smooth, reflection will occur.
I tryed to swap the led ballast today. Unfortunateley that did'nt work and now the other side shows the same symphtoms of failing. some of the led's does'nt light up or light as Bright as it should. Again i also checked all the Connections!
Porsche Boxster 2.5L 1999
RedBeauty is offline   Reply With Quote
