Old 07-12-2014, 02:51 AM   #581
WALDMEISTER
BRAN's Avatar
Looks awesome, particlewave!
just wondering, when someone will mod them little trim corners to DRLs
...so they would be useful finally
Old 07-12-2014, 04:39 AM   #582
Nine8Six's Avatar
More headlight pron...
These could be ready by tomorrow, but I'm going to wait a day to see if anything else comes to mind before I re-seal them.
^ Sweeeeet. Charles I think these came out pretty good. Looks tactical
Can't wait for the in-car pics!!!
Old 07-12-2014, 10:26 PM   #583
Pdwight's Avatar
Me Likee
I really like the way these lights are looking PW
Really Like
Cant wait to see these completed
Old 07-13-2014, 09:22 AM   #584
Really Like
Thanks you for the compliment!
When toying with design ideas, I was inspired by the Carrera dual projectors (1 larger, 1 smaller as seen below).
Unfortunately, finding a projector lens smaller than those that we use proved very difficult and there is not much spare room in the headlight with these projectors due to their mount location.
So, I combined the Carrera dual projector with the 918 4 barrel and came up with these. I went through countless combinations before settling on this.
I tried many different ideas; even adding a second inner shroud to the headlight as seen below. The silver on white looked great in mock up, but not so much in the car.
Old 07-13-2014, 06:07 PM   #585
Pdwight's Avatar
Those look good
I like the projects you do, everything looks classy or elegant to me. I always try to make my projects look as close to factory as possible, if you don't have time to do it right the first time how in the world will you find time to do it right the second or third time. What are the two smaller light assembly's on the side for ?
I cant wait to do this to a spare set of lights I have at home, hopefully the job interview will go good next week and I can get back to work so I can order some projectors.
Again really nice work PW....really Nice...and 968 such classy hardware...very well made from the looks of it.
Dwight
Old 07-13-2014, 08:49 PM   #586
Thanks again Dwight, and good luck with the interview!
I hope that you get the chance to upgrade your lights soon. The smaller lights on the side will probably be used as daytime high beam flashers.
HIDs are powered by the low beam circuit and in low beam mode, there is a small cutoff shield that blocks half of the beam. When you turn your high beams on, a solenoid pulls down the cutoff shield, exposing the entire beam.
However, since the HIDs are powered by the low beam circuit, when you try to flash your high beams with the headlight switch in the off position, only the solenoid is activated and no light is output.
For this reason, many opt to leave the reflector chrome and keep the stock high beams on a relay so that when the headlight switch is off, the stock high beams are used for flashing.
When the switch is on, the relay is activated, switching the high beam circuit back to the solenoid and rendering the halogen high beam inoperable.
I wanted a blacked out reflector, so I may use these as the daytime high beam flashers. They are certainly bright enough.
Here's another small teaser
Im still working out the CCFL DRLs and LED projectors. Waiting on parts...
Old 07-14-2014, 04:04 AM   #587
Nine8Six's Avatar
Again, sweet work coming from you Charles!
I'm not into weapons at all but what about filling one side-tube with a green laser for targeting, the other with a high caliber of some sort? Legal there?
(had too much coffee today maybe dunno)
Old 07-14-2014, 04:15 AM   #588
Nine8Six's Avatar
I have these little bad boys on display as well... if one day you think of retrofitting for the third time. 9 parts of yellow for 1 part of blue! Polished lime green
No?
Old 07-14-2014, 08:57 AM   #589
BruceH's Avatar
No?
That's what you need Charles!
2001 Boxster S Lapis Blue
iPad Mini Dash Install
DEPO Tail Lights
Old 07-14-2014, 09:01 AM   #590
Pdwight's Avatar
Red
I want a pair of those in Red
Old 07-14-2014, 09:24 AM   #591
Nine8Six's Avatar
red
You and I both. I'm going extreme tho... getting the Luminoso installed this summer
^ funny bit is those things are so much more nicer to look at in real life
Old 07-14-2014, 09:32 AM   #592
Pdwight's Avatar
Can thos be made to say "Porsche" on the front ?
Old 07-14-2014, 09:43 AM   #593
Nine8Six's Avatar
edit: Wrong info, irrelevant for now. Will update when concrete info is avail
Old 07-14-2014, 10:03 AM   #594
Nine8Six's Avatar
Old 07-14-2014, 10:16 AM   #595
Nine8Six's Avatar
Aug 1st, going LIVE
Old 07-14-2014, 10:26 AM   #596
BruceH's Avatar
You are going to do very well with that site Fred! Excellent product
DEPO Tail Lights
Old 07-14-2014, 10:34 AM   #597
Nine8Six's Avatar
You, and other who purchased a kit, will need to register to this site eventually so to get their warranty effective. Parts, ballasts, bulbs, anything burns during a two years period you get a replacement for free no question asked.
Something like that lol You'll see. Trying to play clean with the crowd
Last edited by Nine8Six; 07-14-2014 at 11:05 AM. Reason: too much info.... more to come later i guess
Old 07-14-2014, 10:46 AM   #598
Nine8Six's Avatar
dimension drawings
Old 07-14-2014, 11:37 AM   #599
No?
This was my third
I have a problem with headlight addiction, I think.
That green is so cool looking! Not sure I could pull it off, but I might just try
Old 07-14-2014, 11:57 AM   #600
BruceH's Avatar
Great, much appreciated!
DEPO Tail Lights
