03-31-2013, 09:49 PM
San Diego Boxster
DIY 6.5 Inch Door Speakers Using OEM Baffles
This is part of my 1998 Boxster Project: 1998 Boxster Project - Complete Restoration
I've installed a new stereo system into my Boxster, including new 6.5" Polk Audio Speakers for the doors. They're mid-range speakers. I will go over the entire install in another post. In this one, I just want to show how I was able to use the stock OEM Baffles with larger speakers.
When I search for how to install larger door speakers, all I found was a DIY for replacing the OEM baffle with a cutout of MDF.
Here if what I found:
I wanted to use the OEM baffles instead, so here is what I did.
First I removed the speakers from the baffle.
Using a Dremel with a cutting wheel, I removed the face and the top and bottom sides surrounding the speaker opening. I cut along the seam of the baffle. I left the edge where the speaker wire attach intack so that the MDF would be sandwiched in between.
I then cutout squares of cardboard to create a template for the MDF I would cutout.
Once I had the template, I cutout squares of 1/2" MDF that I would secure to the baffles. I secured the MDF to the baffles with JB Weld. Once it was hardened I sealed the any openings where the MDF butt against the plastic with silicone. I later realize there really wasn't a need to seal the openings, as I ended up drilling holes in the back of the baffle to allow air to pass in and out of it.
Once I stalled the modified baffles in the doors, I saw I had to trim a bit of the MDF away so the door panel would fit properly. Notice the holes I drilled in the back of the baffle to allow air to pass in and out.
And here is the final step. I installed my new Polk Audio 6.5" Mid Range speakers. The entire system sounds amazing.
I will post the Amp, Head Unit, Dash Speakers and Rear Speakers I used as well. Just wanted to show how to get larger speakers in the doors without losing the baffles.
Happy Boxstering!
Miles
1998 Black Boxster (owned since 2001)
04-02-2013, 11:56 PM
looks nice will be doing my 2004 same way thanks for the great info,keep us posted
04-11-2013, 11:31 AM
very useful info thanks.
04-11-2013, 10:27 PM
Oh man I did 6.5s with the MDF cutout last year after I got stiffed on some custom baffles. I really like this idea, I wonder if mine would sound any better done this way...
04-15-2013, 12:19 PM
San Diego Boxster
I think you would get better sound as a mid & low range speaker seems to always sound better when you have it in an enclosure. But be sure to drill the holes in the baffle to allow air to pass in and out.
Happy Boxstering!
Miles
05-14-2013, 05:06 AM
1998 Boxster
I really like the use of the original enclosure. I have never used jb weld. Does it create a good bond?
You mentioned that you installed mid range co-ax speakers. I have heard that by design, the door speakers are to provide lower, bass like sound, and that the amp only sends lower frequency signals to the door speakers.
If true, I wonder how the mid range coax speakers work out, and, is the tweeter essentially unused?
05-14-2013, 08:44 AM
Aftermarket stereo
Not sure if the stock stereo is set up like you said, but it wasn't much good anyway.
05-14-2013, 03:25 PM
San Diego Boxster
The stock amp is setup to only use "sub-woofer" or base frequencies for the door speakers. And the mid-range speakers sounded HORRIBLE with the stock amp. But once I tore that sucker out and put in the new amp, all that changed and they sound amazing!
Happy Boxstering!
Miles
05-14-2013, 03:27 PM
San Diego Boxster
Oh, and JB Weld creates a very strong bond. However, I would not recommend using it to fix your engine parts (as I've seen on the web  ). But for plastic and wood bonding, great stuff.
Happy Boxstering!
Miles
05-14-2013, 06:51 PM
Wish I'd seen this post a few days ago...
I've just installed Kicker KS60 into the stock OEM door baffles. This is apparently a 6" speaker, not the customary 6.5" size. I was able to simply screw it into the stock hole locations. It didn't fit into the recessed space so it sticks out more then the OEM speaker, but the door panel fit just fine on top of it.
I'm changing the head unit tomorrow, can't wait to see your amp recommendation as I didn't have anything planned for that.
2015 M3 Sedan
2010 535xi
2004 Z4 3.0i
05-14-2013, 10:26 PM
San Diego Boxster
Happy Boxstering!
Miles
05-15-2013, 03:28 AM
1998 Boxster
I just purchased new 6.5" door speakers. (Not coax). My intention is to replace them using the stock amp. After reading this thread, I think I may be making a mistake. As the existing door speakers sound absolutely terrible, I suspect these may not be much of an improvement if the real problem is the factory amp. I suspect a new amp may have been the first thing to replace and then the speakers. I will find out soon enough. Hope to have my new woofers installed this weekend.
05-15-2013, 05:30 AM
Wow, that's a nice sub. I appreciate you posting all this info, and don't mean to be a pest, but I have a few more questions if you don't mind...
Does it actually fit flat under the seat, or did you install it at an angle against the bulkhead?
Did you have to remove the seat?
Can you share some info about the wiring? I'm wondering where you grounded the sub to...
And the $$ question - where did you source the amp from?
2015 M3 Sedan
2010 535xi
2004 Z4 3.0i
05-15-2013, 09:56 PM
San Diego Boxster
No problem. I was hoping it would fit under the seat, but it did not. To it just rests behind the seat like in the picture. Its easy to take out when I need to too. Only had to remove the seat to run the wires. But the seat was already out for another project. The sub is grounded under the seat where other other items are already grounded.
The Blaupunk amp was from a Canadian supplier $250 and the Sub was from a UK supplier $300.
Happy Boxstering!
Miles
07-12-2013, 05:50 PM
Nice project. When will you be posting the write-up to your install?
Was it a PITA to remove the door covers to get to the baffle...?
07-12-2013, 11:07 PM
San Diego Boxster
I hadn't planned a write-up at this time. But if you tell me what you need, I will do my best to answer.
The door panels are pretty easy to remove. Pretty sure if you search the forum, someone posted instructions.
Happy Boxstering!
Miles
09-26-2013, 03:57 PM
Where did you buy your inPhase woofer from?
10-05-2013, 11:42 AM
San Diego Boxster
Go to ebay.co.uk and search "in phase power subwoofer"
I'm probably going to buy a second one to put behind the passenger seat. I love this product!
Happy Boxstering!
Miles
06-08-2014, 12:07 PM
Interesting! Do the stock door grills still fit? How do they sound? Thanks
06-08-2014, 12:24 PM
They sound much clearer and cleaner than the stock ones, particularly midrange. Bass is less muddy, but not necessarily significantly stronger. I think the speaker size limits the amount of bass it can produce.
Anyway, my car is now sold. Unfortunately I sold it before I managed to install the last addition, a Clarion 8" powered subwoofer.
http://www.amazon.com/gp/product/B00B43LKEM/ref=oh_details_o00_s00_i00?ie=UTF8&psc=1
I tought it might fit behind the passenger seat, if not under the seat. I guess I'll never know now - and I can't even return it now anymore...
2015 M3 Sedan
2010 535xi
2004 Z4 3.0i
