Originally Posted by adc
Wow, that's a nice sub. I appreciate you posting all this info, and don't mean to be a pest, but I have a few more questions if you don't mind...
Does it actually fit flat under the seat, or did you install it at an angle against the bulkhead?
Did you have to remove the seat?
Can you share some info about the wiring? I'm wondering where you grounded the sub to...
And the $$ question - where did you source the amp from?
No problem. I was hoping it would fit under the seat, but it did not. To it just rests behind the seat like in the picture. Its easy to take out when I need to too. Only had to remove the seat to run the wires. But the seat was already out for another project. The sub is grounded under the seat where other other items are already grounded.
The Blaupunk amp was from a Canadian supplier $250 and the Sub was from a UK supplier $300.
