Old 06-01-2015, 01:00 PM   #101
Fintro11's Avatar
did anybody end up getting some video of the before / after?
Fintro11 is online now   Reply With Quote
Old 06-01-2015, 05:30 PM   #102
Originally Posted by rfuerst911sc View Post
Yeah I am familiar with them as I have two of them on my cat delete pipes. I was just curious if the 2 " will fit both sides of the U tube ? I assume yes but wanted to make sure before I order them.
Yes is the answer you seek, young skywalker (they would let me just say yes, not enough characters)
Old 06-01-2015, 05:31 PM   #103
Originally Posted by sjbox View Post
Had the TSPro exhaust installed without any bypass/delete pipes and now have the infamous drone problem. Looking at getting the "catless test pipe", also from TSPro. Can someone help me with other parts that I need to get along with the test pipes?
While installing the exhaust, my mechanic had to cut the C-pipe (or is it called U-pipe?) between the exhaust and secondary cats because the angle wasn't right between the exhaust and secondary cats with the C-pipe as is.
Now, if I am replacing the secondary cat section with the test pipes, do I need a new set of C-pipes? And, what's this clamp business?
Go to Napa and get the 2" Easy Clamps, trust me don't screw around, just do yourself a favor and install them. You can thank me later.
Old 06-01-2015, 07:02 PM   #104
BruceH's Avatar
Yep, get the clamps. I get a grin every time I go under a bridge or better yet, a tunnel Serious sound, no drone.
2001 Boxster S Lapis Blue
iPad Mini Dash Install
DEPO Tail Lights
Old 06-06-2015, 08:58 AM   #105
ASE Certified Idiot
gtoger's Avatar
I'll admit, I got this exhaust system purely for looks. It's a cheap enough way to get rid of what my wife not-so-lovingly refers to as the car's butt-hole. I took mine to an exhaust shop and had it welded in rather than use clamps, because I've got bad history with the clamps.
It's a bunch louder now. Jury is still out on if I like it or not but I'm promising to give until at least the next oil change to pass judgement. I *think* I like it, but I need more miles under varying conditions, and I understand it takes some miles to break them in properly.
One thing I did notice is they appear to ship with a coating that, once heated, will flake off in a fine white powder. It wipes right off and doesn't alarm me, just thought I'd mention.
A picture of the installed exhaust:
To my eye, this is the sort of exhaust tips the car should have shipped with originally.
2003 Porsche 986 Boxster S, Black / Tan
RIP: 1998 Porsche 986, Arena Red / Savanna Beige (wrecked)
1990 Pontiac Trans Am GTA .:. 1990 Corvette ZR-1 (#1930) .:. 1992 Pontiac Firehawk (#010)
1931 Ford Model A Tudor .:. 1967 Pontiac GTO .:. 1986 Pontiac Trans Am basket-case
gtoger is offline   Reply With Quote
Old 06-06-2015, 09:26 AM   #106
BruceH's Avatar
Yes, give it some time, the sound will improve. Be careful about wiping anything off of your paint! The exhaust will shed fiberglass for a while. Wiping it off dry will cause scratches I used a hose to wash it a way.
DEPO Tail Lights
Old 06-06-2015, 09:31 AM   #107
Nine8Six's Avatar
RE drone; not sure if this relevant but did the aftermarket exhaust swap also and wrapped the pipes from mufflers up to the front cats (asbestos wraps? dunno the name of that stuff). It cancelled all of the drone I was getting in the mid revs. Sounds fab now... in and out of car
Later wrapped the headers also. Keeps the bay cooler
Wroom wroom in tunnels here also Bruce loll big time (5~6k rpm and all man)
Old 06-06-2015, 10:03 AM   #108
BruceH's Avatar
Wroom Wroom, oh yeah
DEPO Tail Lights
Old 06-06-2015, 10:06 AM   #109
ASE Certified Idiot
gtoger's Avatar
Oh wow! That's what that is? OK. Yeah, thanks for that tip! I'm anxious to get things broken in. Meanwhile, I kept the old exhaust... just in case.
Old 06-06-2015, 10:46 AM   #110
BruceH's Avatar
My old exhaust sat in the garage for awhile, now it's in the attic
DEPO Tail Lights
Old 06-06-2015, 03:06 PM   #111
ASE Certified Idiot
gtoger's Avatar
Curious on what I should do now that the new exhaust is on. Will the EMC (computer) re-calibrate itself? Do I need to unplug the battery and let it all reset? Something else? Nothing?
Old 06-06-2015, 03:49 PM   #112
BruceH's Avatar
Nothing, except take it for a nice, long, spirited drive. It will learn
DEPO Tail Lights
Old 06-12-2015, 08:10 PM   #113
Fintro11's Avatar
I had to cut the one pipe to make it fit, but holy **************** the sound is good
Old 06-13-2015, 07:01 AM   #114
BruceH's Avatar
Glad you got it on! Drone? Wait until you get some miles on it, it only gets better Remember, do not brush off the white fiberglass that you will see on the bumper. Rinse with water! Have a great weekend
DEPO Tail Lights
Old 06-13-2015, 08:53 PM   #115
Fintro11's Avatar
comparison video
Old 06-14-2015, 08:19 AM   #116
BruceH's Avatar
Outstanding video Martin! Thanks for doing and posting. Sounds great
DEPO Tail Lights
Old 06-18-2015, 07:18 AM   #117
happygilmour's Avatar
Question…I bought a slightly used Top Speed type exhaust with no hardware. Will the old mounting bolts to the trans work?
Should I replace the clamps that go from the U pipes to the cats with easy clamps or just use the old ones? Thanks!
_________________
1999 BOXSTER
happygilmour is offline   Reply With Quote
Old 06-18-2015, 11:41 AM   #118
Send a message via Yahoo to Chard
If you want to replace clamps (I'd recommend) I have a set for sale that I never installed before selling the car. These sleeves were recommended earlier in this post to cure exhaust leaking. Top Speed's Cat Back System Installation
http://986forum.com/forums/boxster-parts-sale-wanted/57342-parting-out-red-white-tails-pass-mesh-wind-screen-etc.html
Present:
'08 e90 335i, '00 986 S
Past:
'99.5 B5 A4 1.8tqms, '02 e46 m3 convertible
Chard is offline   Reply With Quote
Old 06-18-2015, 12:57 PM   #119
Easy Clamps. In case you missed it in the numerous other posts on the subject let me give you a little reminder
INSTALL THE EASY CLAMPS GET 2" ORDER THAT SIZE FROM NAPA!!!!!!!!!
okay i'm calm again, geez (LOL)
Old 06-18-2015, 02:58 PM   #120
Nine8Six's Avatar
Originally Posted by Fintro11 View Post
comparison video
Omg, man that sounds far better than mine :/ This mod has to be day-and-night for you. Nice vid comp
