Old 09-05-2012, 02:42 PM   #1
1999 base
Meir's Avatar
A/C evaporator replacement-A/C foam flakes
Step 1 -Heater removal:
LINKS AT POST 5
Old 09-06-2012, 08:22 PM   #2
Moderator
A very useful link! I am plum tired of foam hitting my face while driving. Thank you!
Old 09-07-2012, 11:39 AM   #3
SoK
that's what she said...
BOOM!
2001 Seal Gray 5-Speed - 2007 Yamaha R6 - 2003 Honda Civic EX - 1999 Nissan Frontier XE - 2003 Coleman Utah
SoK is offline   Reply With Quote
Old 10-22-2012, 06:05 PM   #4
Carnut
AndyA6's Avatar
Thank you! What a nice write up!
'14 Boxster
Old 08-31-2017, 04:47 PM   #5
1999 base
Meir's Avatar
New links
Heater core removal
https://www.dropbox.com/s/6bi2dlsy47ygaky/step%201%20heater%20core%20removal.pdf?dl=0
Dash removal
https://www.dropbox.com/s/lcthesknynmqaaz/step%202%20Dashboard%20cover%20removal.pdf?dl=0
Evaporator replacement
https://www.dropbox.com/s/gja11v6yi6h6sq9/step%203%20Evaporator%20replacement.pdf?dl=0
Old 10-03-2017, 08:15 AM   #6
pjq
Great work Meir.
Old 10-04-2017, 05:07 PM   #7
1999 base
Meir's Avatar
Originally Posted by pjq View Post
Great work Meir.
Thank you Sir.
Hope it helps.
Old 11-30-2019, 09:35 AM   #8
Motorist & Coffee Drinker
78F350's Avatar
It's been a couple years since this post had a bump. I replaced the heater core today on a '99 and Meir's instructions are still the best. The dropbox links are still good and I've saved the .pdfs to my 986 folder. Thanks Meir.
Old 08-17-2021, 09:41 AM   #9
My "new" 2003 Boxster
I'm picking foam flakes out of the vents in my "new" 2003 Boxster. I'll be using Meir's directions in a few months when the weather is cooler and I have more time on my hands. Thanks to Meir for great documentation.
woodgeek is offline   Reply With Quote
Old 08-18-2021, 03:54 PM   #10
Meir's method is the "Purest" method IMHO. For my 2003, I chose the shortcut method which just requires removal of the radio, HVAC and horsehoe and switches, although you do have to cut a piece of the plastic ductwork for the center vents and then tape it back together. It is documented by 78F350 on page 2 of this thread on the forum and in this YouTube video by TTGator.
Even on a 2003, the plastic interior trim is still 18 years old, and some of it may break taking it apart, so the less you have to mess with, the better. Plus you have to open up the cooling and A/C systems in the Meir method. So I'm throwing this out there in case you weren't aware of it and wanted an easier way. But if you're up for the full Meir method, I understand.
Old 08-23-2021, 10:38 AM   #11
The issue with Meir's method is that it only addresses 1 of the flaps. There are 2. To do it completely you have to use both methods or just do it all through the dash.
2000 Boxster Tiptronic
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
1986 944 (gone but missed)
Old 08-26-2021, 11:48 AM   #12
This is great, thank you Meir!
safesaxbdd is offline   Reply With Quote
Old 08-29-2021, 07:17 PM   #13
1999 base
Meir's Avatar
Once you have the air box on the bench, and wide open, you will get access to all flaps from all directions.
With that said, I went thru all this trouble not to replace the foam on the flaps
The main reasons was to replace a leaking AC evaporator.
Old 08-29-2021, 07:19 PM   #14
1999 base
Meir's Avatar
You welcome.
Hope it will help.
Old 09-15-2021, 12:37 PM   #15
Javi Cooper is offline   Reply With Quote
