11-08-2010, 03:27 PM
#21
Hi, just did a search and loads of old posts but he does not seem to be still about.
Darn and drat.
12-29-2010, 10:52 AM
#23
Hi thank for the info, but i've just bought the kit from Porsche-apart. I'm guessing all the kits should come with 4 speakers? Also is the front to rear wiring already in place? I have a CDR22 and the with upgraded sound system, ie door speakers and the amplifier, if that makes any odds.
Thanks, Andrew.
12-31-2010, 01:59 PM
#24
I also have the CDR220.
It's been a few years since I installed my PNP kit, but I think it has 4 speakers.
The kit came with the front-to-rear wiring, which was the most time-consuming part of the install. (Initially they sent me the wrong cable, but followed up quickly with the correct one once I let them know.)
This is one mod that's a must-do, for sure.
01-02-2011, 04:18 PM
#25
Originally Posted by BMAN_986
I've been thinking about this and ready for it now. I have cdr220, and what else do I need except speakers and wires? Any wiring harness for cdr220? Should I connect the speakers (two per each side) in series or the other way? I'm thinking of cutting 1/8" thick black plastic sheet to make it fit. Could you share the template? Thanks in advance.
John
11-06-2013, 12:01 PM
#26
I will be trying this soon
11-06-2013, 06:05 PM
#27
11-18-2013, 06:54 PM
#28
I just installed the kit from Suncoast. Install was about 5 hours. Results are...meh. Not sure the new sound is worth the $325.
'01 Boxster S
11-19-2013, 12:11 PM
#29
Thanks for the honest evaluation! Saved me some money.
2003 Boxster S
1991 BMW 318is
'93 Ducati 900SS
'76 BMW R75/6
'73 Honda Scrambler
12-12-2013, 01:22 PM
#30
are the rear shelf speakers wired in series or parallel? Planning on doing this upgrade as a DIY project and wonder which would provide better sound. Based on my understanding wiring them in parallel sounds like the better idea. I would probably add an amp for those 4 rear speakers also.
99 Porsche Boxster
01-05-2014, 11:31 PM
#31
I'm interested in this too. I'd most likely buy some 8 ohm speakers and wire them in parallel.
Tony
01-06-2014, 06:36 PM
#32
Beginner
It's going to depend on the speakers and amp. How you wire will depend on what impedance are you shooting for.
2003 S manual
03-14-2014, 06:23 PM
#33
I installed my Pioneer 3 1/2" speakers today, the stock ones were crumbling. I used the original plastic mount by enlarging the openings a little bit with a dremel but not too much. The sound is excellent now! The speakers are wired in parallel.
I also replaced the door speakers with 6 1/2" speakers( http://986forum.com/forums/general-discussions/49796-found-6-5-speakers-fit-door-without-mods.html) and replaced the dash speakers( Dash Speaker Replacement) All pioneer. A big thanks to all of those who have posted on here in the various threads that I used
2001 Boxster S Lapis Blue
iPad Mini Dash Install
DEPO Tail Lights
03-15-2014, 02:10 AM
#34
I got mine installed in the "engine cover". Great sound.
Got a 3 way DLS system with basses in the doors, 4 speakers at the front, and 2 in the back.
02-15-2015, 09:45 AM
#35
As an update, I was not happy with the look of the modified OEM bracket so I sent an email to Euro Motorspeed concerning the brackets they include in their kit. I ended up talking to Toi and ordered just the brackets. I wish I had done that in the first place! The brackets are of excellent quality and fit the 3.5" Pioneers perfectly. Even though no one ever sees the modified brackets, I knew what they looked like and it bothered me. I know, I have issues  The brackets cost $65 shipped and IMO are worth every penny considering you would not have to spend the time to modify the OEM plastic brackets. The Euro ones are metal and are a perfect fit.
DEPO Tail Lights
02-17-2015, 08:32 PM
#36
Bruce,
Thanks for the info on the brackets. They are nicer than stock, and certainly nicer than MDF! I am going with Panasonic all around also. I am even going to try out a Panasonic under seat sub woofer from a Subaru Impreza
Defectfully
Patrick
02-17-2015, 08:48 PM
#37
On the slippery slope
Originally Posted by Hogosha
Bruce,
I'm looking at that sub as well
Let me know how it works for you
2004 996 Targa Tip
Instructor - San Diego region
02-17-2015, 08:56 PM
#38
Jay, A dealer not too far from me has several used one's, I will probably go pick one up this week.
Defectfully
Patrick
02-18-2015, 07:11 AM
#39
I would be curious about those subs as well.
DEPO Tail Lights
02-18-2015, 08:11 AM
#40
2004 996 Targa Tip
