Old 11-14-2017, 03:01 AM   #1
Change distilled water coolant?
I use distilled water with water wetter for cooling. Car winters in heated garage. Is it necessary (or prudent) to drain and change on a schedule?
Deadeye is offline   Reply With Quote
Old 11-14-2017, 04:35 AM   #2
schnellman's Avatar
No to straight water
You should be using a 50/50 blend of water and coolant year 'round. The coolant has additives that not only prevent freezing and raise the boiling point, but provide rust protection and lubrication. Porsche recommends its own (expensive) brand of coolant. However, any good brand such as Prestone, will do. And, leaving the system dry is not a good idea.
Old 11-14-2017, 05:12 AM   #3
My car lives in a heated garage and I follow a once a year drain interval. I refill with two bottles of water wetter + distilled H20. Done this for years with no ill effects.
MaxD is offline   Reply With Quote
Old 11-14-2017, 05:39 AM   #4
steved0x's Avatar
I think the water wetter also provides the lubricants and things that you would normally get when running a 50/50 antifreeze blend.
Old 11-14-2017, 10:09 AM   #5
I should have said this is a track only car from April to October.
Old 11-14-2017, 11:37 AM   #6
Also it is OK to drain and leave it dry if you suspect freezing temps (i.e. the power goes out). We had to drain every night when running the (late) Grand Targhee hillclimb at 7851 ft. Just refilled in the morning with jugs from the room and you are on your way.
Old 11-14-2017, 03:10 PM   #7
I use distilled water + water wetter in my Spec Boxster.
I change it every 2-3 years to replenish the additives in the water wetter because the water wetter gets slowly diluted over time as I top up using only distilled water.
Water alone is a better conductor of heat (+17% heat capacity at 220F as compared to 50/50 antifreeze). Plus, in the case of a leak/incident, water + water wetter doesn't create an oily slick on the track like antifreeze.
Old 11-14-2017, 04:52 PM   #8
AZ986S's Avatar
My indie and chief PCA instructor here in AZ recommended distilled water and water wetter. I initially disagreed with him about the reduced boiling temp compared to 50/50 mix but it is true that it extracts heat better. I think that the coolant system pressure elevates the boiling point of water so 220F is fine. I live in AZ so it doesn't affect me too much. Also what THSTONE said about loosing coolant on the track... that makes sense to me if you track your car a lot. I do wonder however about the anti corrosion properties of the antifreeze...
2002 Boxster S - NHP 200 Cell Headers,test pipes,Borla CatBack,Competition Plenum,74 mm TB, EVOMS Tune,Tarett UDP,Eibach Swaybars,BIlstein PSS9s,TuneRS rear toe links,wheel studs,15 mm wheel spacers on all 4,EBC yellow stuff pads,Sebro rotors, EBS oil baffles,160 deg Thermostat,2 quart Accusump,full filtration remote oil filter,rad fan switch,custom gauge/switch plate, Race Capture data logging, 90K miles
AZ986S is offline   Reply With Quote
Old 11-15-2017, 07:51 AM   #9
...Plus, in the case of a leak/incident, water + water wetter doesn't create an oily slick on the track like antifreeze.
Exactly. Point in case... this recent Nürburgring 14 car pileup. Unfortunately, cause was preventable two ways... first running WW as opposed to coolant. More importantly someone did not fix the well documented coolant hose pop-off issue of 996/997 Turbo, GT3, GT2 and GT3RS... First hand saw a similar incident a few years ago at Mid-O when a 996's popped in Madness... 8-9 cars collected quickly against tirewall before corner worker could flag traffic.
P-car and other carnage not for faint of heart... Thankfully the injuries limited from what I've read:
Another camera...
Freak 14-car pile-up mars otherwise perfect weekend | BridgeToGantry.com
LIFESAVING lesson E30 driver ignored was 'unless you/your car are on fire... stay IN your vehicle until safety personnel are on scene and advise you to exit'. He was EXTREMELY lucky on a number fronts... Not to mention the driver who stayed on track side of armco
Be safe
"Cool Prius!"
- Nobody
Old 11-15-2017, 12:52 PM   #10
Yes, that's why I use water and not coolant. What I am asking is if the water with water wetter needs to be peridically changed.
Old 11-15-2017, 01:59 PM   #11
All OEM coolant, in spite of "lifetime" monikers need changed. In most cases though "lifetime" means until some other part's lifetime ends resulting in dumping much of your coolant; at which point you have to replace
WW will break down w/ extensive & extreme hi-temp exposure (google can help you find their MSDS and ASTM spec info).
All in all though, you're not going to find a "frequency guide" b/c too much depends on how and under what conditions you use your car... same w/ oil changes and brake bleeding/flushing. In most cases those minimally are annual and every two or three years respectively (usage dependent).
Personally, I err on side of caution and change more frequently than not. You know, I've never had a motor (or service adviser for that matter) complain about too frequent oil change. Well one time a BMW SA did but that's another story... And, in the grand scheme of things it's VERY inexpensive for the cheap insurance provided.
In short, YES needs changed periodically.
Good luck
"Cool Prius!"
- Nobody
Old 11-15-2017, 03:56 PM   #12
I've never had my coolant analyzed...
Using Tom's schedule (which I have used in many cars, again with no ill effect ), on the second year the mix tends to discolor. Does this mean something is awry, probably not.
My M3 has a cast iron block and the coolant looks cloudy and brown after a few months.The boxster stays clean with a red/pink hue on the yearly scheme and my interval is mostly based on taking something apart that needs the coolant drained.
For track cars, run water and a supplement of whatever brand you find handy. Straight H20 works too.
Having the system dry is fine but don't start the car! It's all too easy to do on extended projects ( I put warning post-its everywhere now)
Please, no glycol on the tarmac.
Old 11-15-2017, 05:30 PM   #13
Topless's Avatar
Distilled plus water wetter works fine and the only downside I can see is losing some of the corrosion protection from OEM coolant that protects your T-stat, water pump, and internals. All coolant should be changed periodically as it does get contaminated over time. Following thstone's schedule makes sense to me.
