Old 11-15-2017, 02:59 PM   #11
Burg Boxster
All OEM coolant, in spite of "lifetime" monikers need changed. In most cases though "lifetime" means until some other part's lifetime ends resulting in dumping much of your coolant; at which point you have to replace
WW will break down w/ extensive & extreme hi-temp exposure (google can help you find their MSDS and ASTM spec info).
All in all though, you're not going to find a "frequency guide" b/c too much depends on how and under what conditions you use your car... same w/ oil changes and brake bleeding/flushing. In most cases those minimally are annual and every two or three years respectively (usage dependent).
Personally, I err on side of caution and change more frequently than not. You know, I've never had a motor (or service adviser for that matter) complain about too frequent oil change. Well one time a BMW SA did but that's another story... And, in the grand scheme of things it's VERY inexpensive for the cheap insurance provided.
In short, YES needs changed periodically.
Good luck
"Cool Prius!"
- Nobody
