06-26-2014, 06:05 AM
#1
Moving up to Street Prepared worth it?
Here’s my current situation: I have a few sessions of autocrossing under my belt but this is the first season I’ve run every event. I’ve gone to classes, participated in practice events and have done 77 runs in total this year alone. Currently I’m tenth in points in my club and I know its about car control etc etc but I’m a little competitive and really want to be running in the top 5 of PAX times. Of course my focus will be to continue on improving my driving but I’d like to move into ASP next year with a goal of running in the top 5 Pax. Using my last event which I think is pretty average I’d need to drop 3 seconds off of my 51 second run to put me in the top 5 (including the time penalty from the new classification). In my current class I’m about .6 seconds behind (still a lot of time!). So the question in (which is not easy to answer) will coilovers, wide Hoosiers and camber plates be enough to drop me 3 seconds? Currently I’m running BF Rivals which aren’t half bad to begin with. I’d like to feel this out before I make a huge investment moving my car up a class. So what do you think is a street prepared setup with Hoosiers worth a WOOPING 3 SECONDS?
Here’s a snap shot of the last event (I did not include anyone below me)
Pax Pos. Pos. Class # Driver Car Model Total Factor Pax Time Diff. From 1st
1 1 ssp 1 Cann, Christopher 04 Chevy z06 47.448 *0.872 41.374 0.000 0.000
2 1 xp 322 Chamberlain, Wade 65 FFR Roadster 46.082 *0.906 41.750 0.376 0.376
3 1 csp 117 Schmidt, Jeff 95 Mazda Miata 48.637 *0.861 41.876 0.126 0.502
4 1 gs 365 Holzer, Stephen 14 Ford Focus ST 52.210 *0.806 42.081 0.205 0.707
5 1 hs 147 Comier, Cortney Cooper 52.941 *0.797 42.194 0.113 0.820
6 1 stc 53 Chenery, Jeff 90 Honda Civic 51.394 *0.824 42.348 0.154 0.974
7 1 csr 161 Chaplin, Kevin 07 Nissan 350Z Nismo 50.985 *0.834 42.521 0.173 1.147
8 1 sts 26 Banks, Joseph 90 Mazda Miata 51.411 *0.829 42.619 0.098 1.245
9 1 cam 51 Inskeep, Paul Merkur 50.776 *0.840 42.651 0.032 1.277
10 1 as 45 Harrison, Robert 07 Chevrolet Corvette 51.300 *0.833 42.732 0.081 1.358
11 1 stx 78 Ogburn, David 09 Mini JCW 51.702 *0.827 42.757 0.025 1.383
12 1 bs 130 Burgh, Stuart 97 Porsche Boxster 51.544 *0.831 42.833 0.076 1.459
1997 Boxster 4.2L Audi V8 Bi-Turbo
2003 911 C2
NASA HPDE Instructor
06-26-2014, 07:03 AM
#2
Track rat
Not likely on a 40 sec AX course. You will continue to drop time as you improve your skill but 3 sec on a 40 sec course is way more than tires and suspension will yield. We figure it's worth 3-4 seconds on a 2 minute racerack. Tires and suspension might buy you 1-1.5 second depending on course design.
06-26-2014, 07:25 AM
#3
Being a mod-aholic, I took the plunge into Street prepared my second season. Although the car itself was faster, I didnt get much faster until I had a lot more seat time. Im in my third season now, and Ive attended almost every AutoX possible... And Im finally becoming a decent driver, but im still midpack.
Have you let any instructors drive your car? That should tell you how far behind your driving ability is vs the cars ability. Ever taken a driving school? My friend, who occasionally codrives my car, went to an autoX driving school, and got so much seat time he had to leave to get gas. There were 45+ runs, and he left with a much better understanding of the cars handling at the limit.
Modifying your car is a lot of fun, but you wont get faster until your technique improves.
06-26-2014, 07:41 AM
#4
I have let a handfull of the instructors drive my car and they haven't beaten me yet. Althought they all drive very different cars as well. I've done a couple classes as well as HPDEs and feel like my ability isn't all that bad, of couse I could certainly improve. I could add a sway bar this season and remain in stock, I wonder if that would help close the .5 second gap at all, .2 seconds would be great! I could also potentially stretch a larger front tire on, I'm currently running a 225 up front. Could I run a 235 over the stock front tire if I used a hard sidewall autocross inspired tire?
2003 911 C2
06-26-2014, 07:50 AM
#5
Track rat
What tires are you currently running? Did you get a performance alignment? An M030 rear sway and wider front tire will allow you to rotate the car more easily. If you have the mod bug, do that.
Having the best possible tire for your class and making the most of it is very important in AX.
06-26-2014, 08:08 AM
#6
I'm running 255 Rivals in the back and Hancook RS3 225s in the front (Rivals don't have that size) but both tires are as competitive as you can get and are apparently very close in carateristics. As I mentioned below I really think I could stretch a wider tire in the front given the stiff nature of these kinds of tires.
They sell a 235/45/17 Hancook RS3. Think that would fit on the front?
2003 911 C2
06-26-2014, 07:16 AM
#7
I'd highly recommend not to mod the car until you're better than the car is. For some people, that's two events and for others (like me) its a whole lot more.
Then when you do mod the car, your driving skills will be ready to take you and the car to the next level where you can extract the extra performance that the car has in it.
Otherwise, you'll just be driving around in a highly capable car at (roughly) the same speed/times you are now. You have to be able to exploit the additional capability of the car or its (somewhat) worthless.
I know that this probably isn't what you want to hear, but it was the BEST advice that I was ever given (by Topless, Brad Roberts, Eric Oviatt, and a few others who know what they're talking about) and it really does work.
Patience and practice. You'll get there.
06-29-2014, 03:52 PM
#8
Some additional data points for you to consider:
My 986S is prepared to the limits of STU. The only trouble is SCCA will not let it run in any ST class. I have protested to no avail - we all know the SCCA always classes P cars badly.
Normally I just run PCA and BMWCCA where I can usually win FTD if I am on A6's. If I run on similar size ST tires (Dunlop ZII's), the penalty is about 3 sec. on a 60 sec. course. At that point, I can sometimes take my class, but FTD is usually out if anyone good is on R-comps.
When I run with SCCA, I run in ASP in a non-PAX group. I ran like that today on NT-01's, and won my class against rather poor competition, and was the fastest car in my session, but a few seconds off FTD.
Cars that are truly prepped to the limits of ASP will be completely stripped and barely street legal. Personally, I don't want to have a street car like that, so I live with the ST prep level, and know that I could not be competitive against a true ASP car that is well driven.
I don't like the PAX system myself, and it will not be your friend if you are not prepped to the limits of ASP.
The best bet is to find some place to run besides SCCA.
Kippis
986S
991S
Van Diemen RF97
06-30-2014, 05:42 AM
#9
Do you mean STR? I believe STU is for 4 seaters, I’m surprised that Boxsters aren’t allowed in STR though when STR allows S2000s, Z4s, Z3s(including Ms), MR2s , RX-7 and basically every other car that out there that is similar to the Boxster. I’d love to run in this class and I think that in a couple of years the Boxsters will be let in, or they’ll kick the S2000 out. Now that I’ve done some more digging and it sounds like the best place to run a Boxster (if there is any) is in Stock Class. Apparently the setup is a GT3 front sway bar, Bilstein Sports, US M030 Springs, 235s up front and either 245s or 255s in the back, I believe this year they have a provision for slicks as well. So that’s my plan, I’d like to run further towards the top on raw times but I guess I’ll have to wait for a rules change or a new car.
2003 911 C2
06-30-2014, 07:48 AM
#10
I just realized that my GT3 seats are probably illegal in Stock… Am I correct that the 25lb fully padded, factory mount rule does not apply to stock? Man I HATE the factory seats, I’d really rather not put those in.
2003 911 C2
06-30-2014, 08:43 AM
#11
STU used to be for sport sedans until they let the C5 Corvette into STU. Otherwise STR and STU are basically the same prep except for allowable tire widths.
For stock (street), but I believe you will need to change back to the stock seats.
Original proposals for Street class allowed camber plates until SCCA figured out the P cars and BMW's would then be competitive. Then suddenly that allowance vanished.
Not sure you can win without fixing the poor front camber situation with these cars. Good luck
Kippis
986S
991S
Van Diemen RF97
07-02-2014, 09:40 PM
#12
I read through ALL the posts.. NOBODY asked him what the car was doing (or not doing) LOL
You don't want ANY piece of ASP.. stay out..
Back to the car: what's it doing or not doing? Low speed understeer? High speed understeer? Low speed oversteer? High speed oversteer?
I tell everyone to leave the cars alone until your ass is calibrated and can tell me/us what it's doing.
Engine Builds, Transmission Builds, Engine Conversions, Suspension Installs, Suspension Tuning, Driver Coaching, Data Acquisition, Video, SCCA/PCA/POC/NASA/GRAND AM/ALMS.
We have worked with amateur and professional drivers for over 26 years. In house machinist, In house fabrication. Our cars, our parts, our engines, our transmission's run nationwide at events every weekend. We work side by side with industry names developing parts.
07-06-2014, 12:45 PM
#13
To your original question, I would say that a street prepared setup and Hoosiers would by worth very close to 3 seconds. However, until the Boxster goes to a turbocharged 4 cylinder, the Boxster is not the best car for ASP compared to the boost buggie AWD cars and the boosted Solstice/Sky. Your car in BS, if you have the Boxster S, is one of the top cars that I think can win in the new BS class. Your time differential to the top 5 can probably be made up going to Version 2 RS-3's all around, as they are proving to be the best street tire for the Street class at this point. I would agree going to a larger rear bar on your car as the stock chassis tends to struggle with push. Also, if you are faster than Courtney, you are driving very very well, keep it up!
Erik Strelnieks
30 years autocross experience, past SEB member, a have prepped a few Championship cars in Stock, SP, Prepared, and Street Modified.
07-07-2014, 02:48 PM
#14
I agree, ASP is dominated by big HP cars... Which class besides stock would you run in, supposing you want to mod the car? I mean, street tires and suspension will only get you so far. I went with coilovers and wide slicks because I wanted the car to go faster, plus, Its a way bigger rush putting down good times....
Erik Strelnieks
For the nationals, didnt the S2000s take the first 10 spots in BS? I think there may have been a boxster or cayman in 13th or 14th place. I dont think they stand a chance in any class with the SCCA
07-08-2014, 09:17 PM
#15
The winning CR S2000 now run in AS under new classification system.
07-09-2014, 06:18 AM
#16
Yes, the S2000 CR was moved up to AS.... I think the Honda S2000 base should be moved up to AS as well.
