04-01-2014, 02:19 PM
#21
Originally Posted by Bigsmoothlee
To the guy holding the temp gun directly at the vent and testing the AC at 70 degrees....
This test is a fail for several reasons.
#1. Holding the temp gun right in the stream of the cold AC makes the reading artificially lower.
#2. Its 70 degs, but what was the humidity?
#3. When its really hot at stop lights, I sometimes rev the engine to 1200 rpm to get some better AC.
Please revise your experiment and show us a AC manifold hooked up and before and after pic with the pressures.:dance:
Really!!!!
OK, here is the new result:
"It broke because it wants to be Upgraded  "
04-02-2014, 05:11 AM
#22
Originally Posted by jb92563
Really!!!!
Well, either way, it isnt going to stop me from installing an underdrive pulley. Did you get any noticeable gains in power?
04-02-2014, 07:03 AM
#23
I think Raby documented a gain of 5 HP when he tested his own cars.
I do feel the noticable increased torque at the lower to mid range.
Couple this with my 2nd cat delete which improved throttle response quite a bit and I now have acceleration from a dead stop that you actually have to manage a bit more to keep traction under control. Plus I have an "S" so its doubly awesome.
Very worthwhile, you wont regret it.
If I only had $700 to do mods then the first would be the 2nd cat delete and after market dual mufflers and the 2nd would be the Under Drive pulley.
04-02-2014, 12:24 PM
#24
A/C works just fine at this end as well.... custom made 4"UD (same as the other stuff) ran for the last 24 months + no issue.
5HP? wouldn't be surprised its a tad more than that
04-02-2014, 07:25 PM
#25
02 box s
Really!!!!
Very funny. Best rebuttal I have seen in ages. Thanks for the laugh.
Gone- 02 boxter s
02 911 carrera2, full leather, tubi exhaust, colored gauge faces, agency power short shift, DOF IMS fix, litronics, tech art shifter, spin on filter adapter
04-03-2014, 07:01 AM
#26
Just trying to educate the kids in the sandbox on how to use a temp gun!
04-12-2014, 11:09 PM
#27
I have the Precision chassis works UDP for about three years now on a daily driver, only issue is a slight skip in audio sometimes at low RPM.
04-13-2014, 12:17 AM
#28
I actually have this same issue. It's happens more frequently when the headlights are on. Otherwise no problems including one 99 degree day last Friday. A/C had no problems cooling the cabin quickly and the coolant temp stayed right on the number 8.
03 Carrera
89 Carrera 4
89 944 S2
78 911SC
04-13-2014, 08:28 AM
#29
I have more of those pulleys available. They are being anodized black now and come with a new OEM bolt. I have 10 more left.
04-13-2014, 08:47 AM
#30
04-18-2014, 08:22 AM
#31
Went with this one off of ebay.
Porsche 986 996 997 4" Under Drive Pulley with AC TRS Motorsports New | eBay
Based on comments from the forum I went with a solid one, I also liked that it had
the same groove pattern and was a complete kit.
If I have any issues -- I'll post, but so far so good.
Thank you for everyones guidance.
Mike
Drivers: '15 Panamera Hybrid (wife's), ' 01 996 GT2, 00 Boxster S, '96 993 Çab/Tip (wife's)
Race Cars: '75 911 RSR Replica & '99 Spec Boxster
mike@lonestarrpm.com
08-23-2014, 09:09 AM
#32
Just had a Mantis 5"installed a couple of days ago. I think I can feel a difference in the 3 to 5 k rpm range.
99 Boxster sold
88 944S sold
Xpit Formula Four sold
95 Integra Solo I sold
71 Opel GT sold
08-23-2014, 11:10 AM
#33
4.5 months in -- so far so good -- no real issues except my water temp will climb a little if I am idling and I do NOT have the AC on.
I think the AC kicks up idle a couple hundred RPM and this is sufficient to spin the H2O pump enough to keep up with cooling needs.
Mike
