Go Back   986 Forum - The Community for Porsche Boxster & Cayman Owners > Porsche Boxster & Cayman Forums > Boxster Racing Forum
Old 04-01-2014, 02:19 PM   #21
jb92563's Avatar
Originally Posted by Bigsmoothlee View Post
To the guy holding the temp gun directly at the vent and testing the AC at 70 degrees....
This test is a fail for several reasons.
#1. Holding the temp gun right in the stream of the cold AC makes the reading artificially lower.
#2. Its 70 degs, but what was the humidity?
#3. When its really hot at stop lights, I sometimes rev the engine to 1200 rpm to get some better AC.
Please revise your experiment and show us a AC manifold hooked up and before and after pic with the pressures.:dance:
Really!!!!
OK, here is the new result:
Old 04-02-2014, 05:11 AM   #22
Really!!!!
Well, either way, it isnt going to stop me from installing an underdrive pulley. Did you get any noticeable gains in power?
Bigsmoothlee is offline   Reply With Quote
Old 04-02-2014, 07:03 AM   #23
jb92563's Avatar
I think Raby documented a gain of 5 HP when he tested his own cars.
I do feel the noticable increased torque at the lower to mid range.
Couple this with my 2nd cat delete which improved throttle response quite a bit and I now have acceleration from a dead stop that you actually have to manage a bit more to keep traction under control. Plus I have an "S" so its doubly awesome.
Very worthwhile, you wont regret it.
If I only had $700 to do mods then the first would be the 2nd cat delete and after market dual mufflers and the 2nd would be the Under Drive pulley.
Old 04-02-2014, 12:24 PM   #24
Nine8Six's Avatar
A/C works just fine at this end as well.... custom made 4"UD (same as the other stuff) ran for the last 24 months + no issue.
5HP? wouldn't be surprised its a tad more than that
Old 04-02-2014, 07:25 PM   #25
02 box s
Really!!!!
Very funny. Best rebuttal I have seen in ages. Thanks for the laugh.
Gone- 02 boxter s
02 911 carrera2, full leather, tubi exhaust, colored gauge faces, agency power short shift, DOF IMS fix, litronics, tech art shifter, spin on filter adapter
sgt brad is offline   Reply With Quote
Old 04-03-2014, 07:01 AM   #26
Just trying to educate the kids in the sandbox on how to use a temp gun!
Old 04-12-2014, 11:09 PM   #27
I have the Precision chassis works UDP for about three years now on a daily driver, only issue is a slight skip in audio sometimes at low RPM.
Old 04-13-2014, 12:17 AM   #28
Porsche9's Avatar
I actually have this same issue. It's happens more frequently when the headlights are on. Otherwise no problems including one 99 degree day last Friday. A/C had no problems cooling the cabin quickly and the coolant temp stayed right on the number 8.
03 Carrera
89 Carrera 4
89 944 S2
78 911SC
Old 04-13-2014, 08:28 AM   #29
I have more of those pulleys available. They are being anodized black now and come with a new OEM bolt. I have 10 more left.
kcpaz is offline   Reply With Quote
Old 04-13-2014, 08:47 AM   #30
Porsche Boxster Cayman 996 997 Underdrive Pulley | eBay
Old 04-18-2014, 08:22 AM   #31
seningen's Avatar
Went with this one off of ebay.
Porsche 986 996 997 4" Under Drive Pulley with AC TRS Motorsports New | eBay
Based on comments from the forum I went with a solid one, I also liked that it had
the same groove pattern and was a complete kit.
If I have any issues -- I'll post, but so far so good.
Thank you for everyones guidance.
Mike
Drivers: '15 Panamera Hybrid (wife's), ' 01 996 GT2, 00 Boxster S, '96 993 Çab/Tip (wife's)
Race Cars: '75 911 RSR Replica & '99 Spec Boxster
mike@lonestarrpm.com
seningen is offline   Reply With Quote
Old 08-23-2014, 09:09 AM   #32
Xpit77's Avatar
Just had a Mantis 5"installed a couple of days ago. I think I can feel a difference in the 3 to 5 k rpm range.
99 Boxster sold
88 944S sold
Xpit Formula Four sold
95 Integra Solo I sold
71 Opel GT sold
Old 08-23-2014, 11:10 AM   #33
seningen's Avatar
4.5 months in -- so far so good -- no real issues except my water temp will climb a little if I am idling and I do NOT have the AC on.
I think the AC kicks up idle a couple hundred RPM and this is sufficient to spin the H2O pump enough to keep up with cooling needs.
Mike
Mike
