Old 02-27-2007, 07:42 PM   #1
Peer's Avatar
Best location for an alarm siren?
What would be the best location for an alarm siren? Currently I have mine mounted inside that space next right to the gas-pedal (don't know what it's called) and it's way too muffled. Any help appreciated.
-- peer
Peer is offline   Reply With Quote
Old 02-28-2007, 04:37 AM   #2
The OEM alarm is located next to the battery on the drivers side (US).
Remove the panel on that side and you should see a horn there.
Take care,
Ed
Sboxin is offline   Reply With Quote
Old 02-28-2007, 03:11 PM   #3
Peer's Avatar
Thank you -- and yes, I just relocated the siren to this very spot.
-- peer
Old 06-10-2013, 11:04 AM   #4
hi guys ive had the same trouble with water! however after chatting to a porsche specialist here is a tip for you, if alarm sounds which is enoying lift hood 10mm spanner wip off the live battery lead , 13mm spanner undo battery retaining clamp move battery to the left ,ok on the right is the alarm ciren undo the nut on the bracket lift siren out on the side you will see the loom is split too 2 conectors top is yellow flat type the bottom is halfmoon and black take the black conector off and insulate with electrical tape refit siren battery and battery lead, everything works central locking windows hood lights etc, the car even starts and drives no problem only thing you dont have is an alarm ciren happy driving boy"s
boxsterboyblue is offline   Reply With Quote
Old 06-11-2013, 11:51 AM   #5
jb92563's Avatar
-- peer
Nobody listens to alarm sirens anymore, why even bother.
What you want is the "Car Zapper 9000" system (Not a joke)
Car Zapper 9000 | NOBODY Messes With MY Car
Or perhaps a "Trunk Monkey" if you like pets.
Trunk Monkey Compilation - YouTube
