Old 06-10-2013, 12:04 PM   #4
boxsterboyblue
hi guys ive had the same trouble with water! however after chatting to a porsche specialist here is a tip for you, if alarm sounds which is enoying lift hood 10mm spanner wip off the live battery lead , 13mm spanner undo battery retaining clamp move battery to the left ,ok on the right is the alarm ciren undo the nut on the bracket lift siren out on the side you will see the loom is split too 2 conectors top is yellow flat type the bottom is halfmoon and black take the black conector off and insulate with electrical tape refit siren battery and battery lead, everything works central locking windows hood lights etc, the car even starts and drives no problem only thing you dont have is an alarm ciren happy driving boy"s
boxsterboyblue is offline   Reply With Quote
