Old 02-15-2025, 04:21 PM   #1
Investigating a fuel smell in the cabin and came across this...
After driving a while I get a gas smell in the cabin. I removed the battery and the battery tray and noticed the top of the sending unit is wet and does smell like gas.
What's a best next step on this one?
Many thanks!!
BoxsterInTheSun is offline   Reply With Quote
Old 02-15-2025, 05:18 PM   #2
Do you not have an engine code for an evap leak? It could be the sending unit or a connector.
spinjockey is online now   Reply With Quote
Old 02-15-2025, 08:15 PM   #3
It seems that you will need to buy a new fuel pump..
Old 02-16-2025, 06:31 AM   #4
Agree that your fuel sender unit is likely failing. The plastic is very discolored so you likely have a crack somewhere.
Old 02-16-2025, 12:48 PM   #5
Thanks everyone! When I went to clean it I noticed that I was able to turn the black ring an entire 360 degrees before I couldn't tighten it by hand anymore.
I highly doubt it's that simple, but would be nice if it is!
Old 02-17-2025, 10:06 PM   #6
Go a step further and use correct specification together with a new seal. Special tool 3217 required or similar. Tightening torque with new union nut and new sealing ring 70 Nm.
If it was loose I gess it was the culprit.
For my understanding, in this case (e.g. crack) would you not only replace part no. 5 or is the recommendation in this case to replace the whole unit?
997_986 is offline   Reply With Quote
