Old 12-09-2024, 01:07 PM   #25
Originally Posted by 997_986 View Post
"Due to production problems, the first 2.5 litre boxster engines had some engine housings in which the cast-in Lokasil mouldings were mechanically removed after casting. New cylinder liners were then shrunk in. Some of these engines subsequently had problems with cylinder liners shifting downwards towards the crankcase. At some point, the liner had moved so far down that the top piston ring jumped behind the top edge of the liner. This of course led to
engine damage."
Exactly how my engine fell apart. It's kind of off topic, because these engines (mine at least) did not get an AT number.
On the other hand, I have an AT engine from a Boxster S which has the non-servicable IMS bearing, and thus definitely different from what it came out with from the factory originally. So, Piper raises a valid point.
Tags
engine number
