Old 12-07-2024, 03:16 PM   #15
piper6909
piper6909's Avatar
Not to be pedantic, if the serial number for your AT engine showed assembly before 2004, it would have had a single row, serviceable IMS bearing; if the date were 2004 or later, it would be carrying the oversized bearing. If the date of assembly came back as late 2003, standard retrofit practice would be to look and see which bearing is in the shaft before ordering parts, just to be safe and not waste time and money as there was definitely some overlap during the changeover.
We do this for a living, so we have seen most, if not all, ways one of these retrofits can go sideways and try to avoid those pitfalls.
So you already knew they're not always the same.
I didn't have the luxury to see which bearing was in the car. I had a really short window of opportunity when the transmission was out for the rebuild, so I had to order everything in advance before taking the car to the shop. Thankfully, Pelican Parts graciously took the bearing back. I can't say the same for LN and the tool I couldn't use.
I just wanted the OP and others to know, in the event they decide to service the IMSB. Peace.
2010 Subaru Forester
