Old 12-07-2006, 07:25 AM   #1
smagerstein's Avatar
Vibration at 2800 RPM
GDay,
Does anyone here get a slight engine vibration at around 2800 RPM. I feel it mostly in 2nd and 3rd gear but also a little in 4th??
Can it be a balance/suspension setting or problem?
Any thought?
Cheers,
Steven
Steven Magerstein
2002 Boxster 2.7 Seal Grey
2008 MB C200k
Past Cars
2006 MB C180k
2005 Peugeot 306
1980 928
2004 Subaru Liberty GT
2000 Nissan Pulsar SSS
smagerstein is offline   Reply With Quote
Old 12-07-2006, 07:32 AM   #2
could also be a motor mount. do you feel it on accel or deccel? turning or straight? do you feel in in the steering wheel, or just behind you?
insite
'99 Boxster
3.4L Conversion
Old 12-07-2006, 07:37 AM   #3
Pretty much feel it a little behind me.
Took the car into the P dealer where I bought it and they took it for a drive and didnt think they noticed anything. So I went out with them as a passenger in the car and pointed it out. They still said it was nothing.
I purchased the car with a warranty from them so if I notice anything getting worse they will see it.
Accellerating Braking Cornering is perfect. Just that Vibration if i sit on 2800 - 3000 rpm in second and 3rd. Its not huge but you can notice it.
Maybe Im paranoid but Im not realy that sort of person.
Steven Magerstein
2008 MB C200k
Past Cars
2006 MB C180k
2005 Peugeot 306
1980 928
Old 12-07-2006, 07:48 AM   #4
I remember a lot of folks on forums complaining about resonance in that same rpm range from after-market exhaust mods. Looks like those are the natural (resonance) frequencies for the 986 body structure, so any source would get amplified in that freq band. Could be the mounts, as insite suggested. Does it sound like an exhaust resonance at all?
'06 Boxster S, 6sp, triple-black
http://i153.photobucket.com/albums/s...05_IMGcrop.jpg
z12358 is offline   Reply With Quote
Old 12-07-2006, 08:01 AM   #5
I dont think so. Exhaust look original
I will ask them about the mounts.
Steven Magerstein
2008 MB C200k
Past Cars
2006 MB C180k
2005 Peugeot 306
1980 928
Old 12-07-2006, 08:58 AM   #6
Also might have them look over the CV joints...
Happy Motoring!... Jim'99
Old 12-07-2006, 09:01 AM   #7
Thanks MNBoxster.
CV joints.
How long generally should these last under norman conditions? I have done 33,000miles
Seems very early for CV joints. But what do I know.
Cheers
Steven
Steven Magerstein
2008 MB C200k
Past Cars
2006 MB C180k
2005 Peugeot 306
1980 928
Old 12-07-2006, 09:14 AM   #8
bmussatti
Posts: n/a
Yes, CV joints should last longer than 33K miles, but if one were damaged, or the protective rubber boot got torn, they can go pretty fast. Dirt can get in there and mess things up quickly.
Old 12-07-2006, 03:43 PM   #9
if it happens in any gear at the same RPM, it's probably not the CV joints since they're speed dependent, not rev dependent. it really could be a lot of things. if the PCar dealer says it's fine, i'd just keep driving and pay close attention to potential changes.
insite
'99 Boxster
3.4L Conversion
Old 12-07-2006, 06:22 PM   #10
I have a similar vibration between 2800 and 3000 rpm.
Mostly on decelleration.
I've learned that it can be the dual mass flywheel that make this vibration.
Do a search on all P-forums and there will be alot of reading.
If you change the enginemount to a new one you might not feel the vibration in the car, but it will still exist!.
I think this is some kind of designproblem in the engine that Porsche don't wan't to talk about due to their reputation
spongebob is offline   Reply With Quote
Old 12-08-2006, 02:31 AM   #11
Thanks for the info,
Cheers
Steven
Steven Magerstein
2008 MB C200k
Past Cars
2006 MB C180k
2005 Peugeot 306
1980 928
Old 12-08-2006, 07:26 AM   #12
Question
I get that vibration on decelleration mostly in top gear on decelleration but I can feel it in 3rd and 4th decellerating. road force balanced all 4 tires iwht no improvement. Heard everything from dual flywheel to variable cams being the cause....oh well I've got a 100k porsche warrenty so not to worried at this point but it is a little disconcerting.
Paul
2004 Boxster
Triple black
stock as a rock
ford40 is offline   Reply With Quote
