Old 06-04-2023, 09:42 AM   #1
compression ratio
Anyone know what the dynamic compression ratio is on 2001 3.2 986?
Race is offline   Reply With Quote
Old 06-04-2023, 12:18 PM   #2
The advertised compression ratio is 11.0: 1
Old 06-04-2023, 01:59 PM   #3
Yes 11.0 to 1 is the static compression ratio. I am trying to figure the dynamic, that should be much lower.
Old 06-04-2023, 02:41 PM   #4
DCR in the range of 8-8.5:1
Old 06-04-2023, 06:15 PM   #5
Perfect thank you I am working on a super charger install and trying to determine if I am going to run into any issues at 6 to 7 psi boost.
Old 06-05-2023, 06:49 AM   #6
Just remember that the DCR moves on these engines within a range because of the Vario Cam functions, and both turbos and blowers are a bad idea for these engines...................
Old 06-05-2023, 01:14 PM   #7
Specially if you are leaving the bottom end stock (conrods & conrod bolts)
Old 06-05-2023, 01:24 PM   #8
Or the pistons, and especially the piston rings. You do not just slap a blower or turbo (or nitrous for that matter) on an engine designed to run normally aspirated and expect it to live for very long....
Old 06-05-2023, 03:16 PM   #9
Completely agree.
Bush Pilot is offline   Reply With Quote
