compression ratio
Anyone know what the dynamic compression ratio is on 2001 3.2 986?
Yes 11.0 to 1 is the static compression ratio. I am trying to figure the dynamic, that should be much lower.
Perfect thank you I am working on a super charger install and trying to determine if I am going to run into any issues at 6 to 7 psi boost.
Just remember that the DCR moves on these engines within a range because of the Vario Cam functions, and both turbos and blowers are a bad idea for these engines...................
| All times are GMT -8. The time now is 12:57 AM. |
