05-03-2023, 07:10 PM
central locking problem
The red light beside the door lock toggle switch on the dash is stuck "on". If I push the button the horn honks twice and the light remains lit. I looked in the owners manual and it says I need to bring the car to the dealer. I'm afraid the dealer is going to charge $2k for what seems to be a minor problem. It seems the passenger door window does not lower/raise upon closing. Otherwise, the car (a 2001 S) runs fine. Is it possible to bypass the central locking system and just unlock the door with a key? Anyone know what the problem is?
05-04-2023, 05:33 AM
1998 Boxster Silver/Red
Uh, yes...
Also, check the relay(s).
1998 Porsche Boxster
05-04-2023, 01:12 PM
Registered Member
99 44/100% probability that there is a bad micro switch in the latch on your passenger side door. Actually, the switch is probably fine, but the plastic face on the cam which actuated it is gone - not that it matters, because the path to a repair is to replace the latch.
There is the Porsche version of the part and the VW version of the part. I bought the VW version… you will have to poke around to find the part number.
05-04-2023, 05:08 PM
When you say "latch" are you referring to what porsche calls a "lock"? In Pelican Parts there are 2 types of locks: with or w/o so called M535 anti-theft 315 MHz. Either a $700 or a $300 part. Yikes. There is a $155 URO part but it doesn't mention the M535 stuff.
05-04-2023, 06:39 PM
05-05-2023, 02:49 PM
Thanks for that 78F350. Do you know what the "M535 anti-theft 315 MHz" stuff is about? What happens if a non-M535 latch/lock is installed into a M535 car (on the passenger side)?
05-05-2023, 03:46 PM
I'm not sure of the differences. I have had Boxsters that did not have a key hole on the passenger side and some that did. That may be related.
Here's some related parts catalog parts.
Option codes:
#14 shown as the entire latch piece in the diagram:
05-05-2023, 05:45 PM
There is much good information on this thread: Windows drop troubleshooting.
05-07-2023, 02:20 PM
My drivers side (offside) window drops when you open the door but when the handle both inside and out goes all the way up and gets trapped in the ridge of the soft top could anyone advise me of the problem and how to solve it please
05-07-2023, 07:20 PM
Start by reading what people wrote in the thread you posted in. The links have lots of info that will help. Like:
Originally Posted by KevinH1990
