Old 10-24-2022, 01:32 PM   #1
Door not locking - 01 Boxster S
I just picked up a 01 Boxster S, and the doors are not locking. They do not lock with the interior door lock button, do not lock with the key fob. When I turn the key to lock the car, it immediately unlocks electronically after I take out the key. The trunk and frunk do not unlock with the remote.
When I press the remote, the horn beeps twice, but the doors do not unlock.
The battery was recently replaced.
What can I troubleshoot for this?
01 Boxster S 6Spd, Speed Yellow w/84k miles. | 991.1 911 C2 7spd Manual | 01 996 C2 -6spd - Green Machine - My baby | 997.2 C2S 6spd | 2x 01 Boxster base
professorman is offline   Reply With Quote
Old 10-24-2022, 08:38 PM   #2
KevinH1990's Avatar
Check the carpet under the driver’s seat to see if it is wet. The immobilizer is under the seat and if it gets wet it can cause problems. Also check for a blown fuse.
If those quick checks don’t identify the problem, I suggest that you use a Porsche-specific scan tool to identify fault codes. I use a Durametric although there are other systems available. http://www.durametric.com/Durametric_Software_Instruction_Manual.pdf
If you don’t want to purchase a tool, you may want to take the car to a Porsche specialist and ask them to scan the car for you. This may cost a few dollars, but it may be less costly in the long run because you will avoid replacing parts on a trial and error basis.
Where are you located in Virginia?
Old 10-25-2022, 03:43 AM   #3
Excellent advice. Thank you so much. I sent you a PM
Old 10-25-2022, 03:21 PM   #4
KevinH1990's Avatar
https://rennlist.com/forums/boxster-and-boxster-s-986-forum/920691-2000-boxster-s-alarm-and-remote-locking-issues.html
Good discussion of possible causes.
Old 10-26-2022, 06:49 PM   #5
Double beep means there is a fault
'98 Boxster 986
'87 911 Carrera Cabriolet
elav is offline   Reply With Quote
