Old 10-24-2022, 08:38 PM   #2
KevinH1990
KevinH1990's Avatar
Check the carpet under the driver’s seat to see if it is wet. The immobilizer is under the seat and if it gets wet it can cause problems. Also check for a blown fuse.
If those quick checks don’t identify the problem, I suggest that you use a Porsche-specific scan tool to identify fault codes. I use a Durametric although there are other systems available. http://www.durametric.com/Durametric_Software_Instruction_Manual.pdf
If you don’t want to purchase a tool, you may want to take the car to a Porsche specialist and ask them to scan the car for you. This may cost a few dollars, but it may be less costly in the long run because you will avoid replacing parts on a trial and error basis.
Where are you located in Virginia?
