Old 06-10-2022, 07:23 PM   #4
There are a lot of micro switches. Which one did you replace? It is probably the latch as elgyqc indicated. Mine wasn’t the typical cracked solder joints but the plastic arm taking a set and not engaging the micro switch there enough. Cheap enough part to simply replace.
elav is online now   Reply With Quote
