Old 03-18-2015, 07:06 AM   #1
DavidsBoxster's Avatar
How to replace a coolant tank in under 2 hours
Well I tackled the job last night. I used a little creativity and was able to get the tank out in under a half hour and the job complete in just under 2 hours. I will post a thread tonight if I can with a detailed description on how I did it with pictures. To give you the short version, I kept reading how the hardest part was getting it out. Since I knew the part was bad and there is no reason to try and salvage the part, I decided to cut it out with my dremel. I basically cut it down to the one tube that goes through the firewall which made removing the oil tube and hoses SO much easier. After that the tube I cut down was exposed and a snap to remove. Used the screw type clamps to reinstall and knocked it out pretty quick. The one downfall is I noticed my oil fill tube was cracked so picking that part up today and bleeding the system tonight.
DavidsBoxster is offline   Reply With Quote
Tags
coolant tank
