Old 07-25-2021, 03:24 PM   #61
Just had a better look at the plugs. Makes no sense. 1-3 look good/normal to me. #4 though looks almost new.
Yes....made sure I am working on the correct sides.
1-3 being passenger, 4-6 being driver.
They look about right considering random misfires on bank one.
Shows that they are firing most times.
I was just looking at the fuel trim data you posted in post #2 I saw something odd.
If I am reading it correctly RKAT is the idle range.
FRA is upper idle to mid range RPM..
Data is showing around 700 RPM
So looking at fuel trim I would expect to see positive fuel trim (RKAT idle range) for the bank with the misfires.
But you have a negative fuel trim for bank 1
and a very strong positive fuel trim for bank 2
Bank 2 trim should be very near 1 for trim it is at 3.42
Is there any possibility that the bank1 and bank2 pre cat O2sensor wires are crossed???
Old 07-25-2021, 03:35 PM   #62
With this car, anything is possible, but that would require flipping the entire engine harness I think. The wires are only so long. dont see how I could even connect the front to rear, rear to front let alone bank 1 to bank 2.
2000 Boxster Tiptronic
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
1986 944 (gone but missed)
Old 07-25-2021, 03:55 PM   #63
Ok thought I would ask
your fuel trim data on bank 2 is what I would expect to see for bank 1.
When you have all three cylinders on the same bank misfiring your O2 sensor is going to see the unused oxygen from the misfires. not the unburned fuel.
So the DME/ECU will see that as a lean condition and add fuel.
But your car is taking away fuel at idle on bank 1
At the same time it is adding lots of fuel to bank 2
Which has no misfires.
Very odd.
your misfires are mostly at idle correct?????
Old 07-25-2021, 04:10 PM   #64
well, take a look at this. Got it all back together. all this time I had been focusing on bank 1. After pulling coils/plugs for the compression test I went ahead and put the new coils & plugs in for bank 2. After seeing what plug #4 looked like had me scratching my head.
Still not seeing the vacuum I should but for the past 20 minutes this is what it has looked like
Idle is too high, saw it shoot to 1012rpm, but....no misfires at idle. Car is up to temp too
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
Old 07-25-2021, 05:04 PM   #65
For compression my understanding is multiply atmospheric pressure x compression ratio, so for our cars it should be on the 160 range. But, conditions vary as does equipment precision, so I always look for consistency rather than raw numbers. This is one reason why leakdown tests can be more helpful. Either way though your numbers look great.
Now that everything is back together you have strong vacuum and your fuel trims are spot on. Looks like you fixed it!
With the idle, it takes a few minutes after a big change for it to level out. Was your ac on though? Idle without ac should be around 650 but idle with ac on is much higher, closer to 1k.
Sent from my SM-G970U1 using Tapatalk
Old 07-25-2021, 05:26 PM   #66
That's just it, dont have strong vacuum at idle. I have great vacuum when the rpms are high, but think I absolutely have a vac. leak.
I can get vacuum up to 20hg around 3k rpm, let off the throttle and watch to drop slowly. Seems to drop faster when all the fans kick in.
Misfires did come back after an hour. They reset themselves to 0 and then when the front fan kicks it they start to climb up again. They are not happening anywhere near like they were before though.
Didn't grab a chart, but I started to graph voltage the last time and noticed that it is around 13.5 and then when the engine fan kicks in it goes to down to 13.2 for a bit, then when they front cooling fans kick in it goes down to 12.8 but does start to climb back up to around 13.4.
I'm just rambling, but the past 2 years I have been working on this issue I found 1 person who was having similar misfires and what fixed it was a new alternator. Electrical issues can cause some weird things to happen but I have kept it in my mind since seeing it
AC was off
Here is the video:
https://youtu.be/XqlX4KJZ24U
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
Old 07-25-2021, 05:30 PM   #67
that formula for compression does not work
My 1969 Jaguar E-type XK engine has a 9:1 CR factory spec.for compression is 175 PSI
My 1960 Austin healey BT7 engine has 9:1 CR factory spec. for compression is also 175 PSI
Old 07-25-2021, 05:42 PM   #68
Ok now we are talking fuel trims look like they the should.
You have excellent compression.
Is this car a tip trans. Automatic transmission??? what ever they are called???
Idle RPM is usually higher then a standard trans.
Do you know the idle spec???
I am going to view you video a few more times then get back to you on vacuum testing.
Old 07-25-2021, 05:43 PM   #69
Yes its a tiptronic. Had to get the wife something she would drive
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
Old 07-25-2021, 05:56 PM   #70
Do you know the idle RPM spec???
or how far from spec. it idles at??
Old 07-25-2021, 06:24 PM   #71
Looks like it's the same as Mt cars. 750 +/- 40
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
Old 07-25-2021, 06:25 PM   #72
STI-986
From what I see in your video you "DO NOT" have a vacuum leak
The test for a vacuum leak is like this.
Get the car fully warmed up.
Get idle as close to spec as possible.
Hook the vacuum gauge up.
Let the car idle for 3-5 minutes and observe gauge reading and needle action.
At idle your in the green zone on your gauge. and the needle is very steady.
That is good
Now bring RPM up to 2000 RPM the needle should rise a little and stay steady.
that is what your gauge is doing at 3000 RPM.
If you had a vacuum leak the needle would fall when you held RPM at a higher level.
Do the vac test again. get the car at operating temp.
Do the above test.
Do it closer to 2000 RPM
Then let the engine idle again for a minute or two.
Then do a "snap throttle test"
Go from idle to floored to off throttle very quickly.
Needle should drop to near 0 then rebound above idle reading very quickly.
then it should settle back to idle reading.
Your going to have a little lower vacuum reading at idle then your expecting.
Your reading very very close to my 2000S
The reason is that you have things like vacuum canisters on both your SAI and your EVAP systems along with all the valves and hoses.
If they were blocked off you would probably gain 2 in.hg
Another thing that is going to affect vacuum is the Vario Cam system.
Cam timing changes at around 1500RPM so as you increase RPM the vacuum gauge readings may not be what you expect.
Old 07-25-2021, 06:32 PM   #73
Watch it again, you can see it decreasing while it is idling. The 1st 25 seconds are so you can see it drop, this was at idle.
Did the snap test a couple times, never goes to 0. At the end of the video is it coming down after being held around 3k rpm and you can see it decrease.
With all that said, it is WAY better then it has ever been.
I'm letting it cool down. In the past when it would misfire like crazy turning the car off for a while and then starting it back up again would turn the MIL on. Want to see if that happens again.
My biggest thing I want to solve for now is to get it to just pass emission testing. At worse I want it to get to a point where all 5 of the tests pass even if it does throw misfire codes cause I have a waiver that will get approved if that happens.
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
Old 07-25-2021, 06:36 PM   #74
At 1:24 is when it goes back to idle and you can see it dropping.
at 1:40 the cooling fans start to kick in and it drops even more but hard to tell.
I'll do another video in a bit. want to get things setup with the gauge by the cluster. Want to see if you can spot another issue that happens had really has me stumped (but I think it is all related)
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
Old 07-25-2021, 06:42 PM   #75
Yes watching RPM and the needle is very important.
Hard to relate everything about using that simple little vacuum gauge via the internet
Old 07-25-2021, 06:59 PM   #76
I turned the sound on so I could hear the engine. That little drop in vacuum when the fans kick in is due to a little drop in RPM.
That slow drop at idle looks like you could have some restriction in your exhaust.
Cats may be partially plugged which could lead to random misfires.
When you do your next vacuum test bring the RPM to 2000 and hold it as steady as you can for 2-3 minutes watch the needle. if it drops slowly you have some restriction in the exhaust.
Old 07-25-2021, 07:14 PM   #77
I am doing horrible with holding this one at 2k. My feet just can't get the feel for it.
Have 2 videos uploading right now
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
Old 07-25-2021, 07:16 PM   #78
Here is the 1st one with the snap throttle.
https://youtu.be/IFBKNcp69X4
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
Old 07-25-2021, 07:29 PM   #79
Here is the next one.
https://youtu.be/s5ZbH4Y-GD0
Really start watching around the 2:15 mark and let me know what else you notice besides the rpm & vac gauge.
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
Old 07-25-2021, 07:38 PM   #80
Keep in mind...I dont know what "normal" is or how the vacuum should be. With all the reading & video watching this weekend it just doesn't feel right that it should decrease like it does after going back to idle and I really dont want to tear my 03 apart comparing it against right now since it drives perfectly.
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
