04-06-2021, 12:03 PM
Suggestions for suspension improvements for my 2003 Boxster?
Hi all,
I have an 03 Boxster base that i am looking to improve the suspension and feel/handling on. Currently have stock everything. Car has 74K. Just did IMS/RMS/Clutch/Flywheel so looking to do this on a budget. I only use the car for roads, no track stuff etc.
Thanks in advance for your help and advice.
04-06-2021, 02:15 PM
Originally Posted by 34dean
Hi all,
Dean, by simply replacing the wear down items on the suspension, a fresh alignment and a nice set of tires will set you back between 2-3k... but the handling would be greatly improved (as intended)
Afterwards, you may want to consider a set of H&R sway bars that will help you tie the handling, these are pretty affordable without going down the rabbit hole..
as all the aftermarket goodies for these cars are expensive.
04-06-2021, 04:35 PM
Another option is the M030 sport suspension. It will improve the handling without making it a racecar.
04-06-2021, 06:25 PM
These guys have quality stuff.
www.tarett.com
1989 928 S4 5 spd - black
04-07-2021, 08:03 AM
My suggestions would be to replace sway bar bushings with energy suspensions bushings ($50-60 for front and rear, I posted a diy on them), godspeed coilovers dropped to ROW sport spec height (less than $1k), and then replace other worn items with oem replacements as needed (rear track arms are notorious for being worn and causing a clunk at low speeds over small bumps).
The biggest problem I found on my stock suspension, even though the car only had 40k, was that the struts were completely shot. So much so that the bump stops had completely disintegrated.
For street driving , I personally think that factory sway bars are plenty stiff. There are a ton of fancy aftermarket parts (tarrett makes great stuff from what I hear) but unless you want to go extreme with lowering or giant tires then that stuff is way overkill and frankly not needed to get a good alignment.
When replacing tires, consider going up to 225 in the front. It helps correct the stock understeer.
I also run spacers, more for looks but theoretically a bit wider stance helps.
Speaking of alignments, find a guy who will let you be there for the process. Adjust camber to factory max settings and just a bit of toe on the rear. Make absolutely sure that each side is equal. This is the setup I run and I promise you will be happy for street driving (that topic though can be expanded upon quite significantly though, of you know what I mean  ).
04-07-2021, 09:53 AM
550 Anniversary
For the road I find the Koni FSD marginally better the M030 for roughly the same cost.
04-08-2021, 06:20 AM
Yellow speed coil overs
Dynamic Pro Sport Coilovers 1997-2004 Porsche Boxster (986)
Opinions on these please.
04-10-2021, 09:04 AM
Thanks, all. Great stuff! I am trying to stay under a $2,000 budget and want to get the most bang for my buck.
Also, I am in CT so if anyone has a recommendation of a shop to get the work done at that would be helpful too.
04-10-2021, 09:16 AM
Koni sports all around and new tires can be done for under $1k. Koni orange would be cheaper. Get a good alignment and you will be happy around town. Not sure I would mess with different springs for an occasional driver or mess with adjustable height.
I have found prioritytire.come has good prices on tires and firestone usually mounts them pretty cheap.
2000 Boxster Tiptronic
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
1986 944 (gone but missed)
04-11-2021, 06:22 AM
Thank you. As I a beginner in this area, can you explain what 'Koni sports all around" means?
04-11-2021, 06:42 AM
Koni sports are shocks/struts. all around means on each wheel. The sport models are adjustable but since the rears aren't that easy to get to to adjust there isn't much reason to put them in the rear.
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
04-17-2021, 12:06 AM
What ever you do DONT CHEAP OUT ON SUSPENSION PARTS! I have BC Racing BR Series coilovers on my car and I love them 1300 US, completely adjustable spring rate(30 settings), height adjustments, and stiffness. I have it lowered just to have a 1 finger fender gap right now might go a little lower though  . I'm super happy with them. I know Rennline sells some struts and what not but I don't have any experience with them, their for sure on the list though.
04-17-2021, 03:46 PM
Be careful with going too low. If the coffin arms go below horizontally it completely changes the geometry of the suspension. Look in the factory service manual and you will see specs for row sport suspension height, which is about as low as you can go without things changing drastically.
