Old 04-06-2021, 03:15 PM   #2
Gilles
Originally Posted by 34dean View Post
Hi all,
I have an 03 Boxster base that i am looking to improve the suspension and feel/handling on. Currently have stock everything. Car has 74K. Just did IMS/RMS/Clutch/Flywheel so looking to do this on a budget. I only use the car for roads, no track stuff etc.
Thanks in advance for your help and advice.
Dean, by simply replacing the wear down items on the suspension, a fresh alignment and a nice set of tires will set you back between 2-3k... but the handling would be greatly improved (as intended)
Afterwards, you may want to consider a set of H&R sway bars that will help you tie the handling, these are pretty affordable without going down the rabbit hole..
as all the aftermarket goodies for these cars are expensive.
