Old 01-16-2021, 06:48 PM   #1
Smile Porsche Boxster S Cupholder Problem...
Hello. I own a 2003 Boxster S and the cupholders right now will not hold very much. The cup is supported by a small plastic piece at the bottom and some thin side walls. I was curious if anyone knows of any kits i could put in the top den that are solid and can hold a cup and I don't need to worry about it.. Thanks!
SavageHooper05 is offline   Reply With Quote
Old 01-16-2021, 06:57 PM   #2
Motorist & Coffee Drinker
78F350's Avatar
Put your drink in a sealed thermos and put it away. Drink it before you drive, then again after you drive. Do not drink and drive.
...or get the Ultimate Cup Holder: https://www.ultimatecupholders.com/installation.html
Old 01-17-2021, 02:45 PM   #3
From experience I can tell you those cupholders in the 2003 are useless. They will break, and when they do, a new part is expensive and used ones that aren't broken are hard to find. Then you have to disassemble the entire center stack to remove and replace it. Once I replaced mine, I bought the armrest insert from Suncoast. It's expensive for a couple of pieces of plastic and the position is less than ideal for putting your drink in and taking out while driving, but it holds a drink securely, snaps in and out without any modification to the compartment, and is easy to clean.
Old 01-17-2021, 03:39 PM   #4
BruceH's Avatar
The Ultimate Cup Holder works great
2001 Boxster S Lapis Blue
iPad Mini Dash Install
DEPO Tail Lights
Old 01-17-2021, 05:38 PM   #5
Awesome! Thank you so much for your input! Sadly your link does not seem to be working. But will look into them! Thanks again!!
Old 01-17-2021, 05:42 PM   #6
Ultimate cupholder is fast and easy to install, works with most cups, looks ok (well made but very aftermarket add-on).
Or get the Fischer cupholder from the same vendor and spend twenty minutes mounting it to the passenger side center tunnel (no need to drill metal, 2 screws into the carpet backing will do), flush with the floor. It folds out of the way when not in use, accomodates possibly a wider variety of cups than the Ultimate, is also well made, has a built in tray that will catch minor drips and spills, and the plastic could pass for oem.
I have 2 Ultimate cupholders that take up storage space now, unless I decide to quickly add a second cup holder for a passenger on a long trip. (I only put in 1 Fischer).
IMO The Ultimate is pretty good, but the Fischer is better. ( but takes a bit more time in that it doesn't just slip in between trim pieces)
