Ultimate cupholder is fast and easy to install, works with most cups, looks ok (well made but very aftermarket add-on).
Or get the Fischer cupholder from the same vendor and spend twenty minutes mounting it to the passenger side center tunnel (no need to drill metal, 2 screws into the carpet backing will do), flush with the floor. It folds out of the way when not in use, accomodates possibly a wider variety of cups than the Ultimate, is also well made, has a built in tray that will catch minor drips and spills, and the plastic could pass for oem.
I have 2 Ultimate cupholders that take up storage space now, unless I decide to quickly add a second cup holder for a passenger on a long trip. (I only put in 1 Fischer).
IMO The Ultimate is pretty good, but the Fischer is better. ( but takes a bit more time in that it doesn't just slip in between trim pieces)
