From experience I can tell you those cupholders in the 2003 are useless. They will break, and when they do, a new part is expensive and used ones that aren't broken are hard to find. Then you have to disassemble the entire center stack to remove and replace it. Once I replaced mine, I bought the armrest insert from Suncoast. It's expensive for a couple of pieces of plastic and the position is less than ideal for putting your drink in and taking out while driving, but it holds a drink securely, snaps in and out without any modification to the compartment, and is easy to clean.
