Old 11-22-2020, 03:10 PM   #1
Shacky
Replacement front radiator fans
Been dealing with slight overheating after long idling. Switched relays around with no effect. Turning on A/C and recirculate does not turn on fans. Have witnessed drive side fan come on for a minute at most.
Thinking I need to replace fan ballists and probably fans too.
I see feedback on non Porsche fans that they do not come balanced and have quite a bit of vibration especially in high speed mode,
Any advice is very welcome 🙏
shacky is offline   Reply With Quote
Old 11-22-2020, 03:46 PM   #2
Any advice is very welcome ��
Have you scanned the OBDII live data to see what temps you are reaching??
Also what temps the fans are triggering at??
Bentley book says:
Low speed kicks on above -206.2 Degrees F or A/C switched on.
High speed kicks on above 215.6 Degrees F .
So if they don't kick on with low speed when you turn on the A/C it could be the ballists
Old 11-22-2020, 03:55 PM   #3
Shacky
Bentley book says:
I lost me OBDII reader 🙄. Those temps seem high! But low fans not coming on with A/C. BTW do you have to be on recirc and A/C to turn on fans? Someone told me that but I always thought just turning on A/C does the trick.
Old 11-22-2020, 04:22 PM   #4
Just A/C on
Nope those temps are the spec. for the Boxster.
Taken from the Bentley service manual
Right were my 2000S kicks the fans on at.
Old 11-22-2020, 04:29 PM   #5
Shacky
Just A/C on
Not the highest in this pic. It will go up to end of the “0”. I guess that would be over 200
Old 11-22-2020, 04:32 PM   #6
Shacky
Can’t attach pic
Old 11-22-2020, 05:35 PM   #7
Can’t attach pic
IF your trying to show the temp gauge on your instrument panel that reading is not always the temp that the ECU/DME sees.
That is why I asked in a previous post if you had an OBDII scanner to read your live data.
The ECU/DME sees the temp the temp sensor is reading not the temp the gauge on the instrument panel is showing
Old 11-22-2020, 05:41 PM   #8
If it doesn't turn on with A/C, but turns on high when hot, then it is most likely either the ballast resistor, or the relay. If it doesn't turn on ever, then it is most probably the fan itself.
1941 Dodge Luxury Liner Coupe
Old 11-22-2020, 08:57 PM   #9
Shacky
I swapped the low and high relays for both left and right and no difference. I did not try jumping relay plug.
Old 11-23-2020, 08:15 AM   #10
mikesz's Avatar
When I had issues with my fans I used a jumper in the relay socket to figure out one fan wasnt working at all the other was only on 1 speed. Pedro has a good diy that is what I used as a guide.
99 Porsche Boxster
