Old 11-22-2020, 09:57 PM   #9
shacky
Shacky
Originally Posted by Anker View Post
If it doesn't turn on with A/C, but turns on high when hot, then it is most likely either the ballast resistor, or the relay. If it doesn't turn on ever, then it is most probably the fan itself.
I swapped the low and high relays for both left and right and no difference. I did not try jumping relay plug.
shacky is offline   Reply With Quote
