Old 10-12-2020, 06:42 AM   #1
1998 Boxster Silver/Red
Removed the triangle pan this morning... inepscted underneath... looking into the crannies... and see nothing that would reveal as a failure point. Thre is a fair amount of residual fluid that covered everything. However, again, nothing on top of the engine, nor below, that looks like a fail.
I have a couple of question for our members...
1. Should I drop the tran pan... "inspect" the internals... pull the filter and inspect it? Go from there?
2. Refill with new fluid and see what is the outcome?
Thank you.
1998 Porsche Boxster
Old 10-13-2020, 09:51 AM   #2
Pulled the pan this morning... no debris... no sludge...
Removed the filter... no clumps... looks used/new (replaced it ~1,000 miles ago).
I've Googled and Googled... but am findoing no 'vent' or 'breather' for the transmission in the event of overheating. Does it exist on the 98 Tip? Where is it?
Clearly there was a failure point... but I'm not finding it. I've had the lights under and above... the cranny-mirror... and don't see anything obvious. Absent a troubleshooting suggestion or recommendation I'm considering just buttoning it up... filling it up... testing to see if it moves.
Nothing mixed with the oil or coolant. Engine starts.
Given the low miles on the filter would the brain trust recommend reusing the OEM filter or purchase a new one?
In advance, thank you.
Old 10-13-2020, 05:33 PM   #3
Motorist & Coffee Drinker
78F350's Avatar
Here's the transmission vent on a 2001 Tiptronic. This particular car is a little non-standard, but the vent line on your 98 should terminate near the back of the engine behind the intake.
Old 10-14-2020, 03:50 AM   #4
Thank you, 78, I'll take a look this morning.
Have a good day.
Old 10-23-2020, 01:18 PM   #5
Filled the trans pan... plugged it... started it up... and this is from where the leak is coming.
After I identified exactly from where the leak is coming I restarted the car for a moment putting it into drive. The wheel spun, in idle. I'm assuming this is a good sign for the TC.
It appears I'll be taking it to an indi, unless someone believes this is a carport-doable job for someone with zero AT experience.
Advice welcomed, thank you.
Name:  zz tran leak.jpg
Old 10-23-2020, 04:36 PM   #6
911monty's Avatar
That will be the transmission input shaft seal. It does not require trans tear down to replace but the trans will have to be removed.
Old 10-24-2020, 02:29 AM   #7
Thank you, 911. So... just remove the tranny... replace the seal... button it back up?
