Old 09-09-2020, 02:39 AM   #2
2004 Boxster
Originally Posted by Leo G View Post
Ive seen a few old posts about this but trying to get the answer that suits my scenario.
CDR23 MOST (amp in front NON Bose 4x40). I have the door subs.
If i add rear speakers to the mix, are the traditional head unit connections redundant because of the front amp?
I tried connecting to the rear speaker points in the head unit but nothing.
I have read that i need to go direct into the amp.... but as im already 4 speakers up, i need to change amp to the 6 x40....... if thats the case, is it an easy swap over ? Ie it uses the existing plug and optic inputs? I just need to add the new speaker wires?
Thanks for any assistance.
As far as I know, the rear speakers connect to the B plug (brown) behind the radio, pins 1-2 and 7-8. I pulled one at a scrapyard from an Audi A4...same plug, also found on VW cars. See more info here : Need a little help making sense of Hi-Fi factory stereo wiring (2004 non-Bose)
'04 986 Atlas Gray / Boxster-red / Blue top
EuropaDrive is offline   Reply With Quote
