Old 10-21-2006, 03:31 AM   #1
Radar detectors...
I need to mount my Valantine One in my "new" 2005 Boxster S. Any tips, hins on location, source for power? (I would like to have it mounted semi-permanenly)
Mike
Esoril 540iT is offline   Reply With Quote
Old 10-21-2006, 11:28 AM   #2
ukchris is your man :
V1 Remote Display Mirror
Also from renntech :
http://www.renntech.org/forums/index.php?showtopic=6451
Hope this helps...
Nick
1999 986 ( Black )
1998 MB C280 ( Black )
1999 BMW K1200RS ( Yellow )
2005 Audi A4 ( Red )
Old 10-21-2006, 01:34 PM   #3
Perfectlap's Avatar
I'm assuming you went for the remote box if so I use the cig. lighter for power even though i have hard wire connection as well. Ocassionaly and particularly on local roads (lots of cops) I get a high beaming tail gater. I'll unplug the v1 and plug it back in so that they can see it go off. usually they back off. for max benefit I just use the sun visor clip. for the lazer to effective as possible it has to be sitting up as high as possible. The best mod I saw was in a 911 996 mounted above the rearview and hardwired with the wires running behind the a pillar cover and under the dash
Old 10-21-2006, 02:51 PM   #4
are the radar detectors saving you guys any citations??
around here we have to worry about unmarked cars sneakin up on us. You can pick up on them but you really have to watch the rearview.
meanwhile, my main worry is all the a**holes who run the red lights hittin one of my kids
edit: oops....sorry..... didn't mean to hijack the thread
'04 Black Boxster, 18" Carerra wheels
"If you're not living on the edge, you're taking up too much space."
wild1poet2 is offline   Reply With Quote
Old 10-21-2006, 03:03 PM   #5
I just use mine old-school with suction cups at the bottom middle of my windshield -- wire hanging to the lighter. I also switch it between cars. Been doing this for 12 years now -- dozens of tickets saved.
Z.
'06 Boxster S, 6sp, triple-black
http://i153.photobucket.com/albums/s...05_IMGcrop.jpg
z12358 is offline   Reply With Quote
Old 10-21-2006, 05:51 PM   #6
The wiring is straightforward, I can't remember if the 05 has the phone power connector behind the dash, if so it's a breeze, if not you can just run the wires to the fuse box and tap in to an ignition 12v line with a wire tap.
Where you put it... that's all down to personal preference but it's really either the windshield or between the seats. Ont he windshied my preferred spot was up and right of the mirror just enough so the rear sensor is clear, this only works if you have a remote display though otherwise you'll need to be able to see the arrows. Also note... the dot near where it says "Laser" is the rear laser detector, you might obscure that...
My preference... I had a bracket made to put my V1 between the seats and integrated the remote display in to the rear view mirror. I did 700 miles with it like this in the last 24 hours and I have to say it works great!
V1 Bracket:
Mirror Display:
Chris.
http://www.lawlai.com/sig.jpg
ukchris is offline   Reply With Quote
