Old 07-25-2020, 04:43 PM   #1
njbray's Avatar
Leaking LN Magnetic Drain Plug!
8 days ago I changed my oil and decided to use a brand new LN magnetic drain plug as my old one (18 months old Ln plug) was a little oily but not dripping.
I used the washer it came with it and tightened to 19 foot pounds as per instructions.
SO... It is now leaking and dripping oil on my garage floor! I’m very annoyed as I now have to drain the new DT 40 oil and replace plug.
I will not be using LN plugs again as I don’t think they are fit for purpose or maybe it's the fault of the washer they ship with it. This says it is the 'New improved' version too!
Anyone else had this problem?
Old 07-25-2020, 05:29 PM   #2
Maybe the washer has a flaw . Much more likely than the plug but anything is possible . Mine doesn't leak and I have changed oil at least four times since installing . I do use a new washer each time.
Old 07-25-2020, 06:12 PM   #3
1997 Tip, 2018 Macan
rexcramer's Avatar
How confident are you in the calibration of your torque wrench?
Old 07-25-2020, 06:31 PM   #4
jaykay's Avatar
I think I have been using the same one for ten + years. I have not thought or had reason to replace it
986 00S
Old 07-25-2020, 08:33 PM   #5
rexcramer's Avatar
There are a number of things that can affect the accuracy. Not backing off the spring in storage, dropping it over the years. If it is a high limit wrench 250 lbs, using it at 19 lbs it will probably not be as accurate. There are a number of YouTube videos on how to test and correct a wrench yourself.
Old 07-25-2020, 09:43 PM   #6
jaykay's Avatar
Yes of course torque wrench calibration...... I will check DIY options ........but I was actually referring the mag plug itself.
I have never replaced mine or even thought it was necessary. Is this a common practice???
986 00S
Old 07-25-2020, 07:00 PM   #7
JayG's Avatar
Pull the drain plug with the motor running. IIRC Raby said you could drive with a hole in your oil pan and no oil would drain out.
Then again I could be completely wrong and my memory may be failing
Old 07-25-2020, 07:06 PM   #8
I’ve installed literally a couple hundred of these, not one leaked. They are a well made product.
Old 07-26-2020, 05:38 AM   #9
piper6909's Avatar
I never use a torque wrench on an oil plug. I just snug it up by feel. Is this the first time you changed the oil on the car, or is it just the first time for this new plug? If it's the latter, just tighten it up as you normally have done in past oil changes. Before pulling it completely, you may simply try snugging it up a bit more and see what happens. If it still leaks, there must be a problem with the washer or the plug. Like Rex and others have said, it could also be bad calibration on your torque wrench or even try using a lower limit (smaller) torque wrench. Like Rex said, lower torques aren't very accurate on bigger torque wrenches. Especially on click-type wrenches. You'll notice that the lower you go in torque, the less spring resistance you get. That tells you the spring isn't doing much so it's not as accurate.
2010 Subaru Forester
Old 07-26-2020, 08:51 AM   #10
A Porsche Guy
1PorscheBoxster986's Avatar
That is the torque spec recommendation Paul for the magnetic drain plugs. If you over-torque it then you risk stripping the head leading you down a rabbit hole. The factory torque spec is 37 ft-lbs. The magnetic plug shares the same torque specs as the factory oil filter housing.
I purchase a generic magnetic plug a while back but I didn't use it. I don't recall seeing a crush washer with it. I'm curious from those that are using it. Are you using factory crush washers with these mag plugs?
1PorscheBoxster986 is offline   Reply With Quote
Old 07-26-2020, 09:15 AM   #11
2003 S, Arctic Silver, M6
paulofto's Avatar
Interesting. Just brain storming here but I wonder with the lower torque spec if the crush washer is not doing it’s job if the washer is for the plug with the higher torque spec. Maybe the mag plug needs a ‘softer’ crush washer to make the seal @ 19 ftlbs.
Old 07-26-2020, 12:58 PM   #12
steved0x's Avatar
I've got this on both my 986 and 987, 19 ft/lb plus just a little touch extra for both with OEM washers, no leaking on mine but I have heard of leaking on others. If it was me I would add just a touch of extra tightening but my guess would be maybe a spec of dirt or something around the washer.
Old 07-26-2020, 01:19 PM   #13
Haven't checked on exactly how old mine is, but it's gotta be similar to jaykay's.
Yeah, this has been my approach as well. I had never had a drop of oil from my Boxster in the 14 years I had owned her (excluding the now-fixed RMS seal, which was so miniscule that it never amounted to a 'drop' that actually hit the floor). Then, after the last oil change, I noticed a very few drops over the next week or so. I just tweaked it a bit tighter and haven't had a problem since. Part of my issue (embarrassed to admit, since they're dirt cheap) is that I'd been re-using the crush washer—probably 4 or 5 times. (Have never once had a problem with that practice.) I'll definitely replace it next time.
Frodo is online now   Reply With Quote
Old 07-26-2020, 02:36 PM   #14
Regarding swapping out the plug without draining oil, you can have a helper apply vacuum via shop vac to oil fill in trunk while you swap out bolt. Little to no oil should come out the drain plug. I’ve done this before to get oil sample for analysis without having to worry about draining all the oil. We didn’t have shop vac form a complete seal over the oil fill line but rather regulated the vacuum by hovering the vacuum near the orifice. Good luck!
2004 Boxster S 79K Miles
Htci is offline   Reply With Quote
Old 07-26-2020, 02:59 PM   #15
So...what did you decide to do?
Not having ever used a torque wrench on an oil plug, I can't imagine draining all that expensive oil without trying it. I think you really have to crank pretty hard to strip these out (maybe someone else with a differing experience will chime in here). When I had my issue (last time I changed the oil), I just turned it the tiniest amount further and that did the trick.
If you do drain the oil, I would think you could catch it in a clean container and re-use it.
Old 07-26-2020, 05:57 PM   #16
piper6909's Avatar
Don't be embarrassed, I do the same! HAHA! Even on my Subarus! In fact, the parts guy at the Subaru dealer told me they can be reused. To me it's not about the cost. For some reason I tend to get everything else, but forget the crush washer until I'm halfway into the oil change. I haven't had any leaks either.
Old 07-26-2020, 06:35 PM   #17
EXACTLY!
(I basically got lazy and didn't bother to explain...but typically that's exactly what happens to me! And probably a lot of other people too..)
Old 07-26-2020, 06:57 PM   #18
A Porsche Guy
Thanks Steve for confirming that OEM washers work with the magnetic plug. I'll consider using it on my next oil change. I could see why people hand tighten the magnetic plug especially at 19 ft-lbs. I do the same with the oil filter housing. But at 37 ft-lbs with the factory drain plug I will use the torque wrench. I know others that just hand tighten it like you guys; mag plug or factory.
Crush washers have to be the cheapest Porsche item you can buy. It's a filler item on Pelican Parts for free shipping. Order 50-100 pieces and you're set for the lifetime of your Boxster ownership . It sounds like you guys will forget the new o ring in the oil filter if it didn't come with it already.
Old 07-26-2020, 07:48 PM   #19
Not likely.
We've learned, through time and experience, that crush washers are, by and large, re-usable. That makes them easy to blow off when purchasing parts. I use (and have for many years have used) the spin-on oil filter adapters. So I just buy spin-on oil filters at the local O'Reilly Auto Parts store. Haven't checked, but I suspect they don't stock crush rings for Boxsters (or any other P-car). So I buy the filter, don't worry about the crush ring. It's worked for years, though the various cars I've done oil changes on through the decades. Over all that time I've dripped maybe a dozen drops of oil, and that only with this past oil change in the Box.
When I order parts online, or happen to be at a Porsche dealership (rare, since I do a fair amount of my own work, and go to a favorite indy otherwise; there aren't any dealerships close anymore anyway), I'll get a crush ring or two. If I neglect to do so? No big deal. It's not that I forget to include it (as you seem to imply)...it's that I know full well I can do just fine re-using the old one.
When doing a DIY, the difference between necessity items and re-usable items? Apples and Oranges.
Old 07-26-2020, 09:02 PM   #20
A Porsche Guy
Of course not likely. We've all re-used crush washers more than once and it's usually due to the forgetfulness clearly like some or the occasion purchase of wrong size crush washers . I was simply stating just order a boatload since it's cheap and showing love to the sponsor . I didn't imply forgetfulness. You agreed with piper about forgetfulness and I simply responded. You sure love that crush washer ring Frodo. Don't let it rule you. That's a joke.
