That is the torque spec recommendation Paul for the magnetic drain plugs. If you over-torque it then you risk stripping the head leading you down a rabbit hole. The factory torque spec is 37 ft-lbs. The magnetic plug shares the same torque specs as the factory oil filter housing.
I purchase a generic magnetic plug a while back but I didn't use it. I don't recall seeing a crush washer with it. I'm curious from those that are using it. Are you using factory crush washers with these mag plugs?
