Old 07-22-2020, 10:17 AM   #1
boxster starting problem
Hi all I have a boxster 2001 2.7
Over the last couple of days I've had a little problem starting.
It normally turned over right away and fires up but last week i struggled for a couple minutes getting it to fire up. It turned over ok and and spluttered a little. But wouldn't fire up.
After a couple of minutes it eventually started and was fine for the rest of the week.
I've left it for 2 days and gone out today and same again turns over has the odd splutter and won't fire.
After about 5 minutes ive drained the battery so now need to charge.
Question what could the likely problem be?
I have noticed the last week or so before the issues with starting it would do the odd backfire when overtaking.
Thanks in advance all..
robstuartuk is offline   Reply With Quote
Old 07-22-2020, 02:55 PM   #2
1997 Tip, 2018 Macan
rexcramer's Avatar
Watch the tach, as you try to start it. If it doesn't move, it could be the crank position sensor?
Old 07-22-2020, 03:55 PM   #3
Has you check engine light come on or flashed. Especially during the odd backfire when overtaking.??
How many km on the car.???
Old 07-22-2020, 06:15 PM   #4
A Porsche Guy
1PorscheBoxster986's Avatar
Start by testing your car battery and your alternator. Make sure it's outputting the correct voltage during idle and stressful loads. You said after 5 minutes you drain your battery. I assume that's because you kept cranking it. This will wear out your alternator and lower your battery life. If your battery is older than 5 years old you should monitor the outputs and anything pass 7 years, in most cases, should be replaced.
1PorscheBoxster986 is offline   Reply With Quote
Old 07-23-2020, 04:16 AM   #5
Car has done 130k
The problems I think first started after I was driving home along the dual carageway going up a long steep hill that runs for about 3 miles was only doing 70 at the time but I'd say there would be a fair bit of turbo boost output due to the steepness of the hill. Its one of these hills that has about a 20-30% gradient for a long way.
I got a check engine light that came on about halfway up while overtaking.
When I got home I connected my carrista to the ob2 port and ran a test.
There were 2 fault codes. Stupid me didn't copy them down i just cleared them.
The following day was the first time I struggled for a few mins to get her started.
Then I noticed at idle when reving gently the car would backfire. This wasn't there before the CEL light
Also when overtaking and the car dropped to 3rd she would pop and then go. Car would never backfire prior to the day the CEL
I could be being paranoid but I think certainly overtaking there might be a bit of a loss of power in there now.
After i drained the battery cranking yesterday. left the car for 2 hrs I turned the key and she fired instantly.
This morning she started fine also but again tapping the accelerator at idle warm or cold she will pop a little. I know if I start the car daily she will and start fine apart from the issue with the backfire.
If I don't start the car for a few days it struggles to start.
I've connected the carrista back to the ob2 no fault codes are currently registered.
I'm no expert but my guess is the starting problems and the backfire seem related to perhaps a fuel problem?
Old 07-23-2020, 07:07 AM   #6
Car has done 130k
Old 07-23-2020, 08:46 PM   #7
Brian Minson's Avatar
Sounds like battery, grab a volt meter and test that battery. Watch this video, it might help you figure it out.
https://youtu.be/ZSmehtE8Ctk
Brian
Brian Minson is offline   Reply With Quote
