Old 04-13-2020, 04:09 AM   #8
You can check the PS fluid level on top of the engine, I would start there if you suspect it's that. It's more likely if those spots are below the engine, but farther forward it's unlikely because the PS hoses run under the driver's side. It's hard to tell how far forward/back the spots are from your picture.
The overfill tube bleeds out on top of the motor and the return tube connected to the back of the pump will also leak out on top of the motor when it goes bad or becomes loose. When that happens, fluid will leak from the front and rear of the motor. I've seen it happen a few times. Coolant leaks usually only happen in front of the motor.
Judging by the two separate puddles and where they're in relation to the tires has me thinking it's leaking from the front and back of the motor. A picture of the bottom of the motor would be much more beneficial.
Woody
