02-04-2020, 10:26 AM
Super Moderator
Now Available: Porsche 986/996 MK1 Headlight Conversion Covers
02-14-2020, 06:41 AM
These covers are very high quality, nicely made and look great. One thing that has to be addressed is where the cover meets the edge of the headlight, it is cut too short, see pic. On a black or certain colors you could run a colored tape stripe along that edge and it would cover it. No such luck finding a tape stripe for guards red. Also you should have a option of a set with no turn signal hole. The plug in the hole idea is not the best. I had to return mine.
Just an opinion, trying to be helpful.
02-17-2020, 10:35 AM
WALDMEISTER
The best solution would be to size them a little big bigger, so that everyone can grind/sand them down to their liking. And those could outs should be just cut out markings (blinker/fog light/washer).
But for now, I think they look great and wrap will do the work as a cover up.
As I said before, it seems that the factory gaps were the reason for the wrap work around (just a guess). And there are A LOT of wrap colors choices on the market.
02-17-2020, 11:21 AM
I agree but for the amount of time the producer has put into these, working on since 2017, and the price $400+, you shouldnt have to do anything but paint them.
Over the last several years I've tried six different shades of several diff wrap manufacturers for my own projects and have not found a match. I even ordered custom made to color wrap, very expensive, didn't match so if someone finds a color match for guards red let me know. I'd gladly buy some. 😁
02-18-2020, 10:31 AM
Super Moderator
Thanks for the info - we'll mention this to the producer.
02-19-2020, 05:09 PM
Super Moderator
02-20-2020, 04:59 AM
1998 Boxster Silver/Red
Originally Posted by Dmitry at Pelican Parts
So, Dmitry, does this mean that the anomaly has been corrected? Or, do we still need to fudge with tape or whatever else to correct the design error? Thank you.
1998 Porsche Boxster
03-12-2020, 01:52 PM
WALDMEISTER
Picked mine up from the customs today. PU chemical smell was not so pleasant, will let them sit outside for a day or 2 and it should be fine, I hope.
I have had all the former plastic headlight covers...THESE ARE NEXT LEVEL, guys!
NONE were fitting any better. Pretty thin and flexible, impressive... so a perfect fit is to be expected. I might take a few photos over the weekend.
As expected, the "gap" is very tiny as the cover can be bent a little, adapting to the slope. It wouldn't make sense IMO to put any more material on the covers, as they would ruin the 4mm gap impression.
I will use a gray wrap for the missing 2mm, I guess, which won't ruin the 4mm gap impression. No one will ever see that little workaround, and if so, I don't care...lol
We will see, but I am very confident. having a perfect solution sitting right here.
03-13-2020, 11:05 AM
I couldn't find an acceptable match for guards red. OCD I guess
04-01-2020, 06:13 AM
Just ordered a pair of these. Should receive early next week. Don’t expect great things frankly, but we’ll see.
Rgds, Fred
04-01-2020, 07:30 PM
Please let us know what you think. I'm wondering if they have made any changes.
04-01-2020, 07:44 PM
Will do! Expensive test
Rgds, Fred
04-02-2020, 04:19 AM
Perfect. I’ve been considering these too, so I’m looking forward to what you find. Keep us updated for sure
2001 Tiptronic S in Speed Yellow
04-09-2020, 03:08 PM
Well, they’re in and primed. YMMV, but I think these are going to work out well. Again, YMMV but I don’t see the concern regarding the flunk/headlight join. Looks like it will be fine for me. If not, a little 3M satin black wrap should address any issues.
Researching 3M ‘no carrier’ very thin transfer adhesive ‘tapes’ now. Don’t want to use an adhesive that will harm the headlights and don’t want to use a headlight protection film.
In the pic, the covers are just sitting loose on the headlights so don’t judge the final fitment from this.
Hope to paint this weekend. Stay tuned.
Rgds, Fred
04-09-2020, 03:11 PM
Yes! They look nice. Once they’re painted and fitted I think they’ll look great. Really updates the look of the front end. Again, definitely keep us posted.
04-10-2020, 01:38 PM
Did the final dry fit today. Plan to start painting tomorrow. Had to make the same small trimming mod on each side. It can be seen in the pics. I had no problem to trim and re-contour the edge. Also, I do not have the problem regarding the exposed headlight edge as shown in some posts. YMMV, however due to fender/headlight fitment, how you want the cover positioned, thickness of your tape or adhesive, thickness and fit of headlight film, etc, etc.
To properly test fit I had to apply pressure in the center of the cover to press it to the headlight surface while ensuring that the raised edges around the perimeter were properly positioned. The cover spread toward the edges somewhat when under pressure.
Rgds, Fred
04-12-2020, 05:40 PM
Base coat finished. Generic ‘hyper silver’ for the headlight trim ring with the rest in GT Silver Metallic. Will do a 2k clear coat as soon as the weather cooperates this week.
Rgds, Fred
04-13-2020, 02:05 AM
So far so good. Are you doing the paint yourself? I figured I would just take it to the shop, but I may try it myself.
04-13-2020, 05:06 AM
Piecework things like this I do myself, big things (like the hardtop) I’ll take to a shop. On the Porsche I did the side skirts, side vents, seat backs, head light clear coat and now the headlight covers. Joe Thoth’s painter did the rear spoiler because his price was good. I’ve been painting since I was a teenager working in my dad’s shop, so I’m an ‘ok’ painter. A competent paint shop would have done a better job. It’s a driver not a show car so I’ll be happy with the result if I don’t screw up the 2k clear coat too badly.
IMHO, if you haven’t done a good amount of polyurethane prep and painting I’d go with a competent shop that does a lot of custom work unless you want to gain some experience with the process for future projects.
Rgds, Fred
04-13-2020, 08:34 AM
Bored today, too humid to clear coat so here’s a before / after pic. The covers are just sitting loose on the headlights, they will mount flush everywhere except the frunk lid and practically flush there because the cover edge tapers to nothing along the frunk lid edge. I deleted the headlight washers and replaced the corner pieces in anticipation of this install, so the before pic is after the washer delete was completed.
3M 950-300 transfer tape arriving today. Should not add any detectable mounting height. I’m definitely going to mount them and live with them for a while. First headlight covers I’ve tried that I’m actually considering keeping on the car.
Rgds, Fred
