Old 12-07-2019, 10:15 AM   #1
dmonk's Avatar
How do I repair this????New crankcase????
So the area where the upper idler pulley bolts in, has broken away. Not sure how to go about repairing/replacing this problem. I'm willing to put more money into it if it's an easy fix. But I'm at the point where I may sell it as is($3500). Can it be repaired and how long will the repair last?
dmonk is offline   Reply With Quote
Old 12-07-2019, 10:24 AM   #2
78F350's Avatar
Maybe I'm missing something, but it looks like the broken part is on the alternator, not the engine. If that's the case, it's an easy fix. Replace the alternator.
Old 12-07-2019, 01:07 PM   #3
BYprodriver's Avatar
Alternator mounting points, that can be fixed. But not by the guy that installed the alternator
Old 12-07-2019, 04:20 PM   #4
I agree, the alternator is damaged. Just replace the alternator.
The belt tensioner bracket (PN 99610201603) contains the cradle/sleeve that the alternator bolt sits in, so even if the cradle/sleeve was damaged its not part of the engine block.
With all of that being said, I'll be glad to send $3,500 immediately for your car.
Old 12-07-2019, 04:48 PM   #5
78F350's Avatar
Good post Tom... I was looking for a good picture of the alternator earlier when I commented... I forgot all about that video:
Old 12-07-2019, 07:03 PM   #6
78F350's Avatar
That back window needs some help. If nothing else, try using 3M double sided tape to hold it in place with a bead of Window Weld around the edge to give it a good seal.
Old 12-08-2019, 03:21 AM   #7
dmonk's Avatar
Thank you
YOUR ALL RIGHT! :dance: it's just the alternator ear. I had to take a second look at. I've just been so frustrated with the car and when things go wrong I expect the worst. I came so close selling my Boxster on facebook over an easy repair. Thanks again!
Old 12-08-2019, 08:42 AM   #8
Looks like if you could find the right size Metric bolt & washers you could reuse the alternator if its working well. Probably should have it tested while it's off anyway.
Old 12-09-2019, 05:27 AM   #9
1998 Boxster Silver/Red
I'd like to hear about that crazy rear spoiler setup. Who's idea was that?
1998 Porsche Boxster
Old 12-09-2019, 08:32 PM   #10
I was wondering the same thing. Can you even open the trunk lid with that thing on there. Looks like a German version of a the old dodge roadrunner Daytona
MrBen is offline   Reply With Quote
Old 12-10-2019, 06:28 AM   #11
JayG's Avatar
I am very wary of untested aero. It may look good, but can easily have a negative effect on handling. Aero is a system, not just throwing something on a car
